Author Topic: Match State  (Read 12752 times)
M-dub
Match State
« on: April 19, 2013, 11:17:16 AM »
I'm wondering if there's some kind of function similar to MATCHPROP where it would allow you to match the state of dynamic blocks.  Select a source block and then, the destination blocks.  As long as the blocks are all the same name, it would... match the state.
Re: Match State
« Reply #1 on: April 19, 2013, 12:26:44 PM »
Here is a quick hack, but should work as required:
;; Match Dynamic Block Properties  -  Lee Mac
;; Matches all dynamic block properties from a selected source dynamic block
;; to all selected destination dynamic blocks of the same name.
(defun c:dynmatch ( / blk des inc obj prp src )
    (while
        (progn (setvar 'errno 0) (setq src (car (entsel "\nSelect Source Dynamic Block: ")))
                (   (= 7 (getvar 'errno))
                    (princ "\nMissed, try again.")
                (   (= 'ename (type src))
                        (   (/= "INSERT" (cdr (assoc 0 (entget src))))
                            (princ "\nObject is not a block.")
                        (   (= :vlax-false (vla-get-isdynamicblock (setq src (vlax-ename->vla-object src))))
                            (princ "\nBlock is not dynamic.")
        (and (= 'vla-object (type src))
            (setq des
                (LM:ssget "\nSelect Destination Dynamic Blocks: "
                    (list "_:L"
                        (list '(0 . "INSERT")
                            (cons 2
                                (strcat "`*U*,"
                                    (setq blk (strcase (vla-get-effectivename src)))
            (setq prp
                (mapcar 'vla-get-value
                    (vlax-invoke src 'getdynamicblockproperties)
        (repeat (setq inc (sslength des))
            (setq obj (vlax-ename->vla-object (ssname des (setq inc (1- inc)))))
            (if (= (strcase (vla-get-effectivename obj)) blk)
                (mapcar
                    (function
                        (lambda ( a b )
                            (if (/= "ORIGIN" (strcase (vla-get-propertyname a)))
                                (vla-put-value a b)
                    (vlax-invoke obj 'getdynamicblockproperties)
                    prp
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; Arguments:
;; msg    - selection prompt
;; params - list of ssget arguments
(defun LM:ssget ( msg params / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget params))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
(vl-load-com) (princ)
M-dub
Re: Match State
« Reply #2 on: April 19, 2013, 12:44:26 PM »
Nice-Lee Done! (yes, I said that...)  That's fantastic!  :)
I have some people who often forget to set certain properties and this makes it quick and easy to fix their work.
Thanks!
TimSpangler
  • CAD Naked!!
Re: Match State
« Reply #3 on: April 19, 2013, 12:45:20 PM »
Select the block
<right click> / Select Similar
Properties
Change the state
ACA 2015 - Windows 7 Pro
M-dub
Re: Match State
« Reply #4 on: April 19, 2013, 12:51:41 PM »
Select the block
Properties
Change the state
Way to make me feel like an idiot, Tim. :P
Kidding!  Well, half kidding, anyway.
I should've thought to try that.  Duh...
TimSpangler
  • CAD Naked!!
Re: Match State
« Reply #5 on: April 19, 2013, 12:54:56 PM »
Select the block
Properties
Change the state
Don't feel bad Mike,  I spent an entire day looking into this only to come to this realization........<facepalm>
M-dub
Re: Match State
« Reply #6 on: April 19, 2013, 01:08:48 PM »
Well, thank-you!
(I forgot to say that)
TimSpangler
  • CAD Naked!!
Re: Match State
« Reply #7 on: April 19, 2013, 01:10:24 PM »
You're welcome
Re: Match State
« Reply #8 on: April 19, 2013, 01:46:23 PM »
Thanks!
:D
You're very welcome Mike :-)
RolandOrzabal
  • "memories fade but the scars still linger"
Re: Match State
« Reply #9 on: March 31, 2022, 10:39:11 PM »
Sorry for reviving this thread...
can it be updated so that the attributes in the source dynamic block also matches with the destination?
ribarm
  • Marko Ribar, architect
Re: Match State
« Reply #10 on: April 02, 2022, 02:30:37 AM »
Untested, but you get an idea...
;; Mod. by M.R., @ribarm, DATE : 02.April.2022. - included matching attribute values
(defun c:dynmatch ( / *error* LM:ssget adoc blk des inc obj prp atp att src )
    (defun *error* ( m )
        (vla-endundomark adoc)
        (if m (prompt m))
    ;; ssget  -  Lee Mac
    ;; Arguments:
        (princ msg)
        (setvar 'nomutt 1)
        (setvar 'nomutt 0)
    (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
    (while (= 8 (logand 8 (getvar 'undoctl)))
    (vla-startundomark adoc)
    (while
            (setq des
                    (list "_:L"
                            (cons 2
                                (strcat "`*U*,"
            (setq prp
            (if (= (vla-get-hasattributes src) :vlax-true)
                (setq atp
                    (mapcar 'vla-get-textstring
                        (setq att (vlax-invoke src 'getattributes))
                    (mapcar
                        (function
                            (lambda ( a b )
                                    (vla-put-value a b)
                        prp
                    (if atp
                        (mapcar
                            (function
                                (lambda ( a b c )
                                    (if (= (strcase (vla-get-tagstring a)) (strcase (vla-get-tagstring b)))
                                        (vla-put-textstring b c)
                            att
                            (vlax-invoke obj 'getattributes)
                            atp
    (*error* nil)
HTH., M.R.
M.R. on Youtube
RolandOrzabal
Re: Match State
« Reply #11 on: April 12, 2022, 12:57:37 AM »
        (if m (prompt m))
    ;; ssget  -  Lee Mac
    ;; Arguments:
        (princ msg)
        (setvar 'nomutt 1)
        (setvar 'nomutt 0)
    (while
            (setq des
                    (list "_:L"
                            (cons 2
                                (strcat "`*U*,"
            (setq prp
                (setq atp
                    (mapcar
                        (function
                            (lambda ( a b )
                                    (vla-put-value a b)
                        prp
                    (if atp
                        (mapcar
                            (function
                                (lambda ( a b c )
                            att
                            atp
    (*error* nil)
HTH., M.R.
Thanks will try this out later as i am not in front of the pc currently
