Author Topic: Question about "initget"  (Read 5484 times)
MeasureUp
« on: April 18, 2013, 11:59:03 PM »
I have used "initget" a lot without any problems until I am working on a new code.
In the code, I set two groups of keyword by using "initegt" and this is a sample:
(initget "A B C")
(setq ABC (getstring "\nSelect a Letter (A/B/C): "))
(if (eq ABC "A")
(prompt "Print letter A.")
); end if
(initget "D E F")
(setq DEF (getstring "\nSelect a Letter (D/E/F): "))
If I enter "D", "E" or "F" in the line of "setq DEF...", it returns "Invalid option keyword."
If I enter "A", "B" or "C" it accepts.
Is there anything that I did wrong?
Your helps are much appreciated.
Re: Question about "initget"
« Reply #1 on: April 19, 2013, 12:08:02 AM »
Try this:
(initget "D E F")
(setq DEF (getkword "\nSelect a Letter (D/E/F): "))
MeasureUp
« Reply #2 on: April 19, 2013, 01:33:27 AM »
Sorry, CAB.
The "get-" function in my code was "getkword" instead of "getstring".
Is there anything in the code incorrect?
(initget "A B C")
(setq ABC (getkword "\nSelect a Letter (A/B/C): "))
(if (eq ABC "A")
); end if
(initget "D E F")
« Reply #3 on: April 19, 2013, 03:55:42 AM »
Sorry, CAB.
(initget "A B C")
(if (eq ABC "A")
); end if
(initget "D E F")
Works for me.
BTW. See the square brackets .. try Right-click at the prompt to see an interactive menu with A, B, C as menu items
« Last Edit: April 19, 2013, 04:03:28 AM by Kerry »
« Reply #4 on: April 19, 2013, 02:19:11 PM »
You could also do something like this to "remember" your last selection.
(or *global* (setq *global* "A"))
(initget "A B C")
(alert (setq *global* (cond ((getkword (strcat "\n[A/B/C] <" *global* ">: ")))
    (*global*)
HasanCAD
« Reply #5 on: April 20, 2013, 05:50:02 AM »
Prompting with a Default Option
http://www.lee-mac.com/promptwithdefault.html
« Reply #6 on: April 20, 2013, 07:39:29 AM »
MeasureUp
« Reply #7 on: April 21, 2013, 09:33:05 PM »
Thanks to everyone for the rich info.
However, I couldn't figure out what was wrong in my code.
It forces the user enter "A", "B" or "C" in the line
Otherwise it returns "Invalid option keyword."
It looks likely it holds the variable active:
BTW, I use AutoCAD Mech v2013.
« Reply #8 on: April 22, 2013, 12:33:49 AM »
You must use  a new initget before each getkword.
Did you use this (initget "D E F") just before the getkword ?
MeasureUp
« Reply #9 on: April 22, 2013, 02:51:21 AM »
Yes, I use a new initget as shown on my code in the previous post:
(initget "D E F")
« Reply #10 on: April 22, 2013, 07:03:55 AM »
To clarify, try the following program:
(defun c:doit ( )
    (initget 1 "D E F")
    (getkword "\nChoose a Letter [D/E/F]: ")
    (initget 1 "A B C")
    (getkword "\nAnd Another [A/B/C]: ")
MeasureUp
« Reply #11 on: April 22, 2013, 06:45:05 PM »
(defun c:doit ( )
    (initget 1 "D E F")
    (initget 1 "A B C")
Thanks, Lee.
I tested it and this is what I got:
Command: DOIT
Choose a Letter [D/E/F]: e
And Another [A/B/C]: b
If I copy this line
to command prompt then enter letter "A", "B" or "C" (without quotation marks) it returns "Invalid option keyword" again.
« Reply #12 on: April 22, 2013, 06:46:40 PM »
If I copy this line
As is expected, since an initget expression has not been evaluated prior to the getkword call.
MeasureUp
« Reply #13 on: April 22, 2013, 07:11:49 PM »
Now I copy one line to command prompt per time. This is what I get:
Command: (initget 1 "A B C")
nil
Command: (getkword "\nAnd Another [A/B/C]: ")
And Another [A/B/C]: a
"A"
Command: (initget 1 "D E F")
nil
Command: (getkword "\nChoose a Letter [D/E/F]: ")
Choose a Letter [D/E/F]: d
« Reply #14 on: April 22, 2013, 07:29:32 PM »
Why are you copying the code to the command line? Seems like the VLIDE would be the best place to troubleshoot  :?
