Author Topic: Question about "initget"  (Read 5369 times)
Re: Question about "initget"
« Reply #15 on: April 22, 2013, 11:07:13 PM »
In ACAD2006
Command: (initget 1 "D E F")
nil
Command: (getkword "\nChoose a Letter [D/E/F]: ")
Choose a Letter [D/E/F]: e
"E"
Choose a Letter [D/E/F]: a
Invalid option keyword.
Choose a Letter [D/E/F]: f
"F"
MeasureUp
« Reply #16 on: April 22, 2013, 11:24:06 PM »
In ACAD2006
nil
"E"
"F"
Thanks CAB, have you tried (initget 1 "A B C") first, then (initget 1 "D E F") and (getkeyword "D/E/F: ")?
« Reply #17 on: April 22, 2013, 11:37:24 PM »
Oh it ignores the second initget.  :o
« Reply #18 on: April 22, 2013, 11:39:31 PM »
In VLIDE it behaves normally.  8)
MeasureUp
« Reply #19 on: April 23, 2013, 12:04:43 AM »
I can't find any errors by using VLIDE.
And that is why I don't mention of using it.
From the command prompt, the 1st set of "initget" looks fine:
(initget "A B C")
(setq ABC (getkword "\nSelect A/B/C: "))
Select A/B/C: -> A
"A"
but the 2nd set has a problem:
(initget "D E F")
(setq DEF (getkword "\nSelect D/E/F: "))
Select D/E/F: -> D
« Reply #20 on: April 23, 2013, 01:50:50 AM »
What happens if you put the code into a function body and load the file containing it and run the function.
Not many of us would expect to enter the code line by line at the command line ...
