/// Excerpts from AcDbLinq.cs Copyright (c) 2008-2013 Tony Tanzillo
using System;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.Internal;
using System.Collections;
namespace Autodesk.AutoCAD.DatabaseServices
public static class AcDbLinqExtensions
public static IEnumerable<T> GetObjects<T>(
this IEnumerable<ObjectId> ids,
OpenMode mode = OpenMode.ForRead,
bool openErased = false,
bool forceOpenOnLockedLayers = false ) where T : DBObject
if( ids.Any() )
TransactionManager tm = ids.First().Database.TransactionManager;
RXClass rxclass
= RXClass
.GetClass( typeof( T
/// Call IsDerivedFrom() on each id's ObjectClass only
/// once, and cache the result:
Cache<RXClass, bool> cache =
new Cache
<RXClass,
bool>( objclass => objclass.IsDerivedFrom( rxclass )
foreach( ObjectId id in ids )
yield return (T) tm.GetObject( id, mode, openErased,
forceOpenOnLockedLayers );
/// Use the cache if the RXClass has children:
else if( rxclass.GetHasChildren() )
if( cache[id.ObjectClass] )
else
if( id.ObjectClass == rxclass )
// Returns true if at least one RXClass is derived from
// the given RXClass:
public static bool GetHasChildren( this RXClass rxclass )
foreach( DictionaryEntry e in SystemObjects.ClassDictionary )
if( rxclass == ( (RXClass) e.Value ).MyParent )
return true;
return false;
/// Essentially, a Dictionary<TKey, TValue> that implicitly
/// produces values for keys, using a delegate.
public class Cache<TKey, TValue> : CacheBase<TKey, TValue>
Func<TKey, TValue> getValue = null;
public Cache( Func<TKey, TValue> getvalue )
if( getvalue == null )
throw new ArgumentNullException
("getvalue"); this.getValue = getvalue;
protected override TValue GetValueForKey( TKey key )
return getValue( key );
public abstract class CacheBase<TKey, TValue>
Dictionary
<TKey, TValue
> items
= new Dictionary
<TKey, TValue
public CacheBase()
public void Clear()
items.Clear();
public bool Contains( TKey key )
return items.ContainsKey( key );
public int Count
get
return items.Count;
public TValue this[TKey key]
get
TValue result = default( TValue );
if( ! items.TryGetValue( key, out result ) )
result = items[key] = GetValueForKey( key );
return result;
// Must throw an exception if a value cannot
// be produced for the given key:
protected abstract TValue GetValueForKey( TKey key );
