Author Topic: How to retrieve delimiter from string  (Read 4412 times)
BlackBox
Re: How to retrieve delimiter from string
« Reply #15 on: April 10, 2013, 03:30:04 PM »
@BlackBox: Why the foreach? You could accomplish the same thing thus:
  1. (defun _RemEndDelim (lst)
  2.   (mapcar (function (lambda (str) (vl-string-right-trim ",;\t\n\p" str))) lst))
Oh, well that's easy... You forgot that I am inept, my Zef slang bro.  :lmao:
BlackBox
« Reply #16 on: April 10, 2013, 03:34:42 PM »
Revised function:
  2.   (mapcar (function (lambda (x) (vl-string-right-trim ",;\t\n\p" x)))
  3.           lst
  4.   )
  5. )
  6.
Revised speed test results:
Code - Text: [Select]
  1. _GETDELIM
  2. Elapsed: 624
  3. Average: 0.0624
  4.
  5.
  6. _$
  7.
  8. _REMENDDELIM
  9. Elapsed: 78
  10. Average: 0.0078
  11.
  12.
  13. _$
  14.
... It's just a bit faster, thanks to Irne. :beer:
irneb
« Reply #17 on: April 10, 2013, 04:05:55 PM »
Whaaa ha ha! Inept can be applied to me in some cases too .... no make that all cases depending on which way my head is screwed on at the moment ;)
Anyhow fixo, why would you need to "know" what the delimiter is? Usually with these delimited strings you simply want to split them into usable items.
  1. (defun split-string (input / dPos)
  2.   (if (setq dPos (vl-remove-if 'null (mapcar (function (lambda (del) (vl-string-position del input))) '(44 59 9 10 112))))
  3.     (cons (substr input 1 (setq dPos (apply 'min dPos))) (split-string (substr input (+ 2 dPos))))
  4.     (list input)))
  5.
  6. (defun RemEndDelim (lst)
  7.   (mapcar (function (lambda (str) (vl-string-right-trim ",;\t\n\p" str))) lst))
  8.
  9. (defun split-string-list (input)
  10.   (mapcar (function (lambda (line) (split-string (RemEndDelim line)))) input))
If you need to keep track of the delimiter so you can then later save back the list into a similar file, then by all means use my findDelimiter function:
  1. (defun findDelimeter (input / )
  2.   (substr (vl-string-left-trim ".0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ" (strcase input)) 1 1))
  3.
  4. (defun read-delim-file (fileName / file line lines)
  5.   (if (setq file (open fileName "r"))
  6.     (progn (while (setq line (read-line file)) (setq lines (cons line lines)))
  7.       (close file)
  8.       (cons (findDelimeter (car lines)) (split-string-list (reverse lines))))))
  9.
  10. (defun write-delim-file (dataList fileName / file)
  11.   (if (setq file (open fileName "w"))
  12.     (progn (foreach line (cdr dataList)
  13.              (princ (car line) file)
  14.              (foreach item (cdr line)
  15.                (princ (car dataList) file)
  16.                (princ item file))
  17.              (princ "\n" file))
  18.       (close file))))
fixo
« Reply #18 on: April 10, 2013, 04:20:50 PM »
The reason is on some files were badly formatted, I almost finish my work on today,
Many thanks to all and regards :)
