Author Topic: How to retrieve delimiter from string  (Read 4572 times)
fixo
« on: April 10, 2013, 12:56:00 PM »
Guys,
I hope that someone has a full code, it is necessary for me for urgent work
till this night, or the request is to give me a links to a similar question
I will try to explain an existing situation
Say, i have the delimited text file of such contents:
(comma delimited ending with comma)
"ST1,1022.519,927.347,100.522,"
"KON1,1022.519,927.347,100.522,"
"2,1022.519,927.347,100.522,"
It can be of such contents
(comma delimited without ending char)
"ST1,1022.519,927.347,100.522"
"KON1,1022.519,927.347,100.522"
"2,1022.519,927.347,100.522"
Or even the such
(semicolon delimited ending with comma)
"2;1022.519;927.347;100.522,"
"ST1;1022.519;927.347;100.522,"
"KON1;1022.519;927.347;100.522,"
Or still the such
(semicolon delimited  ending with semicolon)
"2;1022.519;927.347;100.522;"
"ST1;1022.519;927.347;100.522;"
"KON1;1022.519;927.347;100.522;"
ETC... ETC..
Even line may starts from number or alpha-numeric part
The question is how to retrive a separator and to remove
ending separator in every line ( if this exists )
at runtime, in one shot only
What I have stuck on yet
(defun check_del (str_line /)
    ((eq 44 (last (vl-string->list str_line ))) ",")
    ((eq 58 (last (vl-string->list str_line ))) ":")
    ((eq 59 (last (vl-string->list str_line ))) ";")
    ((eq 9 (last (vl-string->list str_line ))) "\t")
    ((eq 0 (last (vl-string->list str_line )))
     (substr (vl-string-trim "0123456789" str_line) 1 1));it's working good, if the first item is numeric only
       (T (alert "Impossible to read your text\nAsk your dork programmer about.")(exit)))
Hmm, I have just 4 hours to finish this work :)
Marc'Antonio Alessi
  • Marco
Re: How to retrieve delimiter from string
« Reply #1 on: April 10, 2013, 01:25:09 PM »
you just need to remove the last not numeric character or you must also know the separator?
BlackBox
« Reply #2 on: April 10, 2013, 01:30:09 PM »
(defun _GetDelim (s) (substr s (strlen s) 1))
(defun _RemEndDelim (lst / d)
  (if (setq d (_GetDelim (car lst)))
    (mapcar
      (function
        (lambda (x)
          (vl-string-right-trim d x)
      lst
Example:
_$ (_RemEndDelim (list "ST1,1022.519,927.347,100.522," "KON1,1022.519,927.347,100.522," "2,1022.519,927.347,100.522,"))
("ST1,1022.519,927.347,100.522" "KON1,1022.519,927.347,100.522" "2,1022.519,927.347,100.522")
_$
Marc'Antonio Alessi
  • Marco
« Reply #3 on: April 10, 2013, 01:33:26 PM »
    (mapcar
      (function
        (lambda (x)
      lst
Example:
_$
fixo
« Reply #4 on: April 10, 2013, 01:34:43 PM »
Hi Marco, glad to see you :)
Yes I want to get separator and remove it at the end
if this is in there, otherwise just to know separator
fixo
« Reply #5 on: April 10, 2013, 01:45:45 PM »
    (mapcar
      (function
        (lambda (x)
      lst
Example:
_$
Thanks so much, your function _RemEndDelim working good
on my files, but function _GetDelim is not good for me,
some time it return number instead of delimiter,
anyway thanks, friend, most part of work I'll be finish
BlackBox
« Reply #6 on: April 10, 2013, 01:58:48 PM »
The _GetDelim function only returns the last character of the sample string. If the sample string does not include a deliminator, then still, the last character is returned.
To qualify that the deliminator returned is in fact a known deliminator, consider this adaptation:
(defun _RemEndDelim (lst)
  (mapcar
    (function
      (lambda (x)
          (vl-string-right-trim ";" x)
    lst
Example:
Code - Text: [Select]
  1. _$ (_RemEndDelim '("ST1,1022.519,927.347,100.522," "KON1,1022.519,927.347,100.522," "2,1022.519,927.347,100.522,"))
  2. ("ST1,1022.519,927.347,100.522" "KON1,1022.519,927.347,100.522" "2,1022.519,927.347,100.522")
  3.
  4. _$ (_RemEndDelim '("ST1,1022.519,927.347,100.522" "KON1,1022.519,927.347,100.522" "2,1022.519,927.347,100.522"))
  5. ("ST1,1022.519,927.347,100.522" "KON1,1022.519,927.347,100.522" "2,1022.519,927.347,100.522")
  6.
  7. _$ (_RemEndDelim '("2;1022.519;927.347;100.522," "ST1;1022.519;927.347;100.522," "KON1;1022.519;927.347;100.522,"))
  8. ("2;1022.519;927.347;100.522" "ST1;1022.519;927.347;100.522" "KON1;1022.519;927.347;100.522")
  9.
  10. _$ (_RemEndDelim '("2;1022.519;927.347;100.522;" "ST1;1022.519;927.347;100.522;" "KON1;1022.519;927.347;100.522;"))
  11. ("2;1022.519;927.347;100.522" "ST1;1022.519;927.347;100.522" "KON1;1022.519;927.347;100.522")
  12. _$
  13.
fixo
« Reply #7 on: April 10, 2013, 02:15:37 PM »
Thanks again it's working good :)
Hve just one issue with _GetDelim, eg:
(_GetDelim "KON1\t1022.519\t927.347\t100.522");<-- return 2
(_GetDelim "KON1\t1022.519\t927.347\t100.522\t");<-- return \t , good one
irneb
« Reply #8 on: April 10, 2013, 02:33:07 PM »
Try this one perhaps:
  1. (defun findDelimeter (input / )
  2.   (substr (vl-string-left-trim ".0123456789ABCDEFGHIJKLMNOPQRSTUVWXYZ" (strcase input)) 1 1))
BlackBox
« Reply #9 on: April 10, 2013, 02:34:15 PM »
Fixo, there's no need for _GetDelim anymore with my last code.  :-)
However, as I did not account for "\t" you might find this more useful:
  1. (defun _RemEndDelim (lst / trim)
  2.
  3.   (defun trim (s)
  4.     (foreach char '("," ";" "\t" "\n" "\p") ;;<-- You set the list to remove here
  5.       (setq s (vl-string-right-trim char s))
  6.     )
  7.     s
  8.   )
  9.
  10.   (mapcar (function (lambda (x) (trim x))) lst)
  11. )
  12.
Example:
  1. _$ (_RemEndDelim '("2;1022.519;927.347;100.522\t" "ST1;1022.519;927.347;100.522," "ST1;1022.519;927.347;100.522" "KON1;1022.519;927.347;100.522;"))
  2. ("2;1022.519;927.347;100.522" "ST1;1022.519;927.347;100.522" "ST1;1022.519;927.347;100.522" "KON1;1022.519;927.347;100.522")
  3. _$
  4.
** Note that there is "\t" "," ";" and no delim used in same list.
fixo
« Reply #10 on: April 10, 2013, 02:43:38 PM »
Thanks again
I thought the same way
That is I ended up with:
(defun _GetDelim (str_line / dels)
  (setq dels (list 9 44 58 59))
  (car
    (vl-remove-if-not
      '(lambda (x)
(member x dels)
       ) ;_ end of lambda
      (vl-string->list str_line)
    ) ;_ end of vl-remove-if-not
  ) ;_ end of car
) ;_ end of defun
The problem was resolved, thanks to all, guys :)
Marc'Antonio Alessi
  • Marco
« Reply #11 on: April 10, 2013, 02:55:00 PM »
here I am after dinner (my wife is severe)...
I glad you solved, good night.
fixo
« Reply #12 on: April 10, 2013, 03:08:27 PM »
Thanks Irne`
findDelimeter woks nice too,
sorry for the bealting
Regards to all, guys :)
What the nice forum !
BlackBox
« Reply #13 on: April 10, 2013, 03:18:08 PM »
I'm glad you got this sorted, Fixo... I guess I was just confused.
Based on this:
Your code:
  1. (defun _GetDelim (str_line / dels)
  2.   (setq dels (list 9 44 58 59))
  3.   (car
  4.     (vl-remove-if-not
  5.       '(lambda (x)
  6.          (member x dels)
  7.        ) ;_ end of lambda
  8.       (vl-string->list str_line)
  9.     ) ;_ end of vl-remove-if-not
  10.   ) ;_ end of car
  11. )
  12.
Returns:
  1. _$ (_GetDelim "ST1,1022.519,927.347,100.522,")
  2. 44
  3.
... You've only identified the deliminator, and still must remove it from the list of strings.
My code:
  2.
  3.   (defun trim (s)
  6.     )
  7.     s
  8.   )
  9.
  11. )
  12.
Returns:
  1. _$ (_RemEndDelim '("2;1022.519;927.347;100.522\t" "ST1;1022.519;927.347;100.522\t" "KON1;1022.519;927.347;100.522\t"))
  2. ("2;1022.519;927.347;100.522" "ST1;1022.519;927.347;100.522" "KON1;1022.519;927.347;100.522")
  3. _$
  4.
My code has already removed all deliminators, for each string in the entire list.
Speed test:
  1. (bench '(_GetDelim)
  2.        '("ST1,1022.519,927.347,100.522,")
  3.        10000
  4. )
  5.
  6. (bench '(_RemEndDelim)
  7.        '(("2;1022.519;927.347;100.522,"
  8.           "ST1;1022.519;927.347;100.522;"
  9.           "ST1;1022.519;927.347;100.522;"
  10.           "KON1;1022.519;927.347;100.522\t"
  11.          )
  12.         )
  13.        10000
  14. )
  15.
Results:
  1. _GETDELIM
  2. Elapsed: 608
  3. Average: 0.0608
  4. _$
  5.
  6. _REMENDDELIM
  7. Elapsed: 390
  8. Average: 0.0390
  9.
  10.
  11. _$
  12.
irneb
« Reply #14 on: April 10, 2013, 03:28:45 PM »
@BlackBox: Why the foreach? You could accomplish the same thing thus:
  1. (defun _RemEndDelim (lst)
  2.   (mapcar (function (lambda (str) (vl-string-right-trim ",;\t\n\p" str))) lst))
