Author Topic: Overkill Command  (Read 16917 times)
Re: Overkill Command
« Reply #30 on: May 06, 2013, 09:28:59 PM »
... it is like tits on a bull.
Thanks Tony.
That takes me back about 50+ years to our next door neighbour on the farm.
He was Irish and another of his favourite sayings was 'Take your hurry boy'.
He had 2 daughters, but that's another story altogether.
TJK44
« Reply #31 on: May 09, 2013, 03:43:56 PM »
I think I found a workaround that appears to work so I don't have to rebuild my project, although I would really like to incorporate Tony's Extension Method  :-(
Code - Visual Basic: [Select]
  1.                 Dim curAcadDoc As Object = Application.DocumentManager.MdiActiveDocument.AcadDocument
  2.                 curAcadDoc.SendCommand("._-OVERKILL" & vbLf)
  3.                 curAcadDoc.SendCommand("_ALL" & vbLf)
  4.                 curAcadDoc.SendCommand(vbLf)
  5.                 curAcadDoc.SendCommand(vbLf)
  6.
Edit:
I lied, this still does not execute synchronously. Back to the drawing board.
« Last Edit: May 09, 2013, 03:56:37 PM by TJK44 »
TheMaster
« Reply #32 on: May 10, 2013, 01:55:45 AM »
  6.
Edit:
If you're still having problems getting the RunCommand wrapper working, you can also use reflection to call it, without the System.Core.dll problem.
Here's a post with the reflection-based version:
http://www.theswamp.org/index.php?topic=43113.msg483306#msg483306
TJK44
« Reply #33 on: May 13, 2013, 02:12:07 PM »
Thanks Tony, that did the trick.
