Author Topic: How do I link a data extraction with an autocad table?  (Read 4839 times)
PFICAD
« on: April 03, 2013, 08:14:31 AM »
I use the Data Extraction API with VB.NET to extract attribute values from blocks in a drawing. The data extraction part works fine but finally I want to link the data  with a table inserted in the drawing the same way as eattext this do.
I found only code snippets to connect with a excel spreadsheet.
Thanks for help!
PFICAD
Re: How do I link a data extraction with an autocad table?
« Reply #2 on: April 03, 2013, 02:41:04 PM »
Hi fixo
Thanks for the hint. The sample from Kean connects to an excel spreadsheet. But I want to link a data extraction result with the autocad table. For the data extraction I used the informations I found here:
http://aucache.autodesk.com/au2008/sessions/3054/CP301-2L_Data-Extraction-API.pdf
I believe that the key to solve the problem is the correct value for the DataLink.ConnectionString property. But I can't find more information about the data extraction API.
PFICAD
« Reply #3 on: April 04, 2013, 04:19:26 AM »
I did some further research. If I use EATTEXT to create a table linked to the block attributes inserted in the drawing, the DataLink.ConnectionString is the full path to the DXE file I used for the data extraction. So far, so good. But now, I have the following problem: If I use the Data Extraction API to create a data extraction configuration programmatically, I can't save the configuration to a DXE file. There is only a function to load a configuration from file (DxExtractionSettings.FromFile). Has anybody an idea, how I can write the settings to a file?
fixo
« Reply #4 on: April 04, 2013, 07:55:26 AM »
I didn't tried to create DXF file,
here is just code to select all blocks from Model
then data would be saved in xml file in the project/debug folder
See if this helps anyway, wait till XML file will be appears at the end
of command
        [CommandMethod("exblocks", CommandFlags.Modal | CommandFlags.Session | CommandFlags.Transparent)]
        public void ExtractBlocks()
            Editor ed = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
            System.Windows.Forms.OpenFileDialog _dia = new System.Windows.Forms.OpenFileDialog();
            _dia.CheckPathExists = true;
            _dia.DefaultExt = "dwg";
            _dia.DereferenceLinks = true;
            _dia.Multiselect = false;
            _dia.Filter = "Drawing (*.dwg)|*.dwg|All files (*.*)|*.*";
            _dia.Title = "Select drawing";
            _dia.FilterIndex = 1;
            if (_dia.ShowDialog() != System.Windows.Forms.DialogResult.OK)
                return;
            string fname = _dia.FileName;
            try
                // following datatable easy to write to the any data file (Excel, Access etc)
                System.Data.DataTable dataTable = ExtractLines(fname);
                // write data to Lines.xml in the Debug folder
                dataTable.WriteXml("blocks.xml");
            catch (System.Exception ex)
                ed.WriteMessage("\n{0]\n{1}\n", ex.Message, ex.StackTrace);
            // Display the file
            Process.Start("blocks.xml", null);
        public System.Data.DataTable ExtractLines(string fname)
            System.Data.DataTable dataTable = new System.Data.DataTable();
            System.Data.DataTable blkTable = new System.Data.DataTable();
            Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            List<string> tags = new List<string>();
            if (!System.IO.File.Exists(fname))
                ed.WriteMessage("\nDrawing file does not exist.");
                return null;
            IDxExtractionSettings es = new DxExtractionSettings();
            IDxDrawingDataExtractor de = es.DrawingDataExtractor;
            de.Settings.ExtractFlags = ExtractFlags.None | ExtractFlags.ModelSpaceOnly;
            //de.Settings.ExtractFlags = ExtractFlags.ExtractBlockOnly;
            //'Or ExtractFlags.ModelSpaceOnly
            IDxFileReference fr = new DxFileReference(Path.GetDirectoryName(fname), fname);
            de.Settings.DrawingList.AddFile(fr);
            // Scan the drawing for object types & their properties
            de.DiscoverTypesAndProperties(Path.GetDirectoryName(fname));
            List<IDxTypeDescriptor> types = de.DiscoveredTypesAndProperties;
            // Select all the types and properties for extraction
            // by adding them one-by-one to these two lists
            List<string> selTypes = new List<string>();
            List<string> selProps = new List<string>();
            foreach (IDxTypeDescriptor type in types)
                selTypes.Add(type.GlobalName);
                foreach (IDxPropertyDescriptor pr in type.Properties)
                    if (!selProps.Contains(pr.GlobalName))
                        selProps.Add(pr.GlobalName);
            de.Settings.SetSelectedTypesAndProperties(types, selTypes, selProps);
            // Now perform the extraction itself
            de.ExtractData(Path.GetDirectoryName(fname));
            // Get the results of the extraction
            dataTable = de.ExtractedData;
            if (dataTable.Rows.Count > 0)
                dataTable.TableName = "Blocks";
                //DataRow[] selrows = dataTable.Select("AcDxObjectTypeName Like '%BlockReference*'");// not working
                DataRow[] selrows = dataTable.Select("AcDxObjectTypeGlobalName Like 'BlockReference*'");
                blkTable = dataTable.Clone();
                foreach (DataRow dr in selrows)
                    blkTable.ImportRow(dr);
            return blkTable;
PFICAD
« Reply #5 on: April 04, 2013, 10:11:21 AM »
I did nearly the same things as you in your code sample. If I link the exported xml file with the autocad table, the autocad table is not updated if a block attribute is changed. As far as I can see, to get a data link with automatic updates, it is necessary to use a dxe file.
PFICAD
« Reply #6 on: April 25, 2013, 03:57:19 AM »
Balaji Ramamoorthy from the AutoCAD DevBlog has created a code sample that exactly covers my question. The sample code could be found here:
http://adndevblog.typepad.com/autocad/2013/04/linking-attributes-and-table-using-dataextraction-api.html
fixo
« Reply #7 on: April 25, 2013, 09:05:24 AM »
Tested on my A2010
It's working like a sharm,
