Author Topic: 2014 a pain in the...  (Read 27523 times)
gile
  • Marseille, France
Re: 2014 a pain in the...
« Reply #15 on: April 02, 2013, 06:06:27 PM »
I tried with a folder containing an acaddoc.lsp file and some other ones added to TRUSTEDPATHS and it works fine.
Re: 2014 a paint in the...
« Reply #16 on: April 02, 2013, 07:03:11 PM »
Also worthy of note, is this line from the TRUSTEDPATHS documentation:
When TRUSTEDPATHS includes a folder that ends with \... (backslash and three dots), all of its subfolders are also trusted.
Example:
(setvenv 'trustedpaths "F:\\...")
(setvenv 'trustedpaths "A:\\...;B:\\...;C:\\...;D:\\...;E:\\...;F:\\...;G:\\...;H:\\...;I:\\...;J:\\...;K:\\...;L:\\...;M:\\...;N:\\...;O:\\...;P:\\...;Q:\\...;R:\\...;S:\\...;T:\\...; "  )
:evil:
kdub in one timeline.
--> Donate to theSwamp<-
BlackBox
« Reply #17 on: April 02, 2013, 07:13:00 PM »
:evil:
You read my mind, for if/when the attempt to utilize this new feature becomes intolerable.  :kewl:
BlackBox
« Reply #18 on: April 02, 2013, 07:22:28 PM »
:evil:
More specifically:
  1.
  2.
  3. (defun c:TrustEverything ()
  4.   (princ "\rTRUSTEVERYTHING ")
  5.   (setvar
  6.     'trustedpaths
  7.     (apply
  8.       'strcat
  9.       (mapcar (function
  10.                 (lambda (x) (strcat (vl-princ-to-string x) ":\\...;"))
  11.               )
  12.               '(A B C D E F G H I J K L M N O P Q R S T U V W X Y Z)
  13.       )
  14.     )
  15.   )
  16.   (prompt "\n... Maybe you should have backed this up first. Just saying. ")
  17.   (princ)
  18. )
  19.
** Tested on AutoCAD 2014
« Last Edit: April 02, 2013, 07:32:26 PM by BlackBox »
« Reply #19 on: April 02, 2013, 07:49:27 PM »
Or perhaps:
(defun c:trustall ( / fso lst )
    (if (setq fso (vlax-create-object "scripting.filesystemobject"))
            (vl-catch-all-apply
               '(lambda ( )
                    (vlax-for drv (vlax-get fso 'drives)
                        (setq lst (vl-list* ";" (vlax-get drv 'driveletter) ":\\..." lst))
            (vlax-release-object fso)
            (setvar 'trustedpaths (apply 'strcat (cdr lst)))
nobody
  • .net stuff
« Reply #20 on: April 02, 2013, 10:44:37 PM »
Y'all have me scared to upgrade lol
JNieman
« Reply #21 on: April 02, 2013, 11:06:42 PM »
Yeah .. I looked at the securepath option and abandoned. These new security features may be wanted by others .. but not me. :-P
Thanks for the solution to his "feature".
I was hoping there was an easy disablement.
My mistake, I replied before reading the entirety of the thread.  I think Kerry hit the nail on the head with the permanent ham-fisted solution.  This is not an elegant 'feature' and as such it deserves an equally inelegant/brute-force solution.
I can't imagine what the hell they were thinking with this one...
« Reply #22 on: April 03, 2013, 03:06:44 AM »
< .... >   I think Kerry hit the nail on the head with the permanent ham-fisted solution.  < ... >
No, No, No, NO ... I'm still looking for a good sarcasm icon, or at least a tongue-in-cheek icon to post with that comment.
My post was more in the vein of 'I know this is going to happen' rather than 'I suggest you do this'
irneb
« Reply #23 on: April 03, 2013, 03:46:35 AM »
Funny aint it? Adesk goes and introduces some "security" measure and the very first thing the users are looking for is: "how to break it so we can actually use the damned product"
Reminds me of  having to set administrator rights simply so acad would start! I think adesk is going beyond the opposite way now. There's always a balance needed between functionality and security (otherwise you get no usability as well as no security), and I think adesk has just tipped that scale into the security side.
They're making the mistake stipulated here: http://www.forbes.com/sites/danwoods/2013/03/11/why-security-without-usability-leads-to-failure
“You cannot have usability in a security system without sensitivity to the work being done,” said Gonen. “When CISOs focus on assets and technical mechanisms, not on the experience of users in doing their work, systems fail from day one and users immediately start working around approved practices, which increases risk even further.”
andrew_nao
« Reply #24 on: April 03, 2013, 08:59:16 AM »
nothing i do makes this trustedpaths option work
my files simply wont load unless the paths are in the support file search path
BlackBox
« Reply #25 on: April 03, 2013, 09:16:42 AM »
So just to confirm....
Try (setvar 'secureload 0).
also tried that, didnt seem to do anything even setting it to 0 didnt help
anything loading out of the "trustedpaths" path, wont load.  (for me anyway)
im also on a 30 day trial as im waiting for my copy to arrive in the mail
Is anyone else also experiencing the behavior here, where executable files are not being loaded outside of TrustedPaths when SecureLoad is zero (0)?
BlackBox
« Reply #26 on: April 03, 2013, 09:19:34 AM »
This requires clarification... How have you been attempting to load your 'files' if not in SFSP?
Specific example would be helpful.
andrew_nao
« Reply #27 on: April 03, 2013, 09:26:43 AM »
i have my files listed in the support path to make them work, if i list them in trustedpaths they dont work
BlackBox
« Reply #28 on: April 03, 2013, 09:36:52 AM »
That suggests that your 'load' call does not include the file path where your file is stored.
I haven't done enough testing to observe that TrustedPaths are, or are not included in LISP's Load function's ability to 'find' the file name parameter in SFSP if not specified, for example:
  1. (load "foo.lsp")
That said, and since this is not specified in the online help, I suspect that TrustedPaths is used as a second stage filter... Meaning that, in the example of a LISP (not sure what code file(s) you're wanting to load), the file path would need to be qualified in both SFSP (in order to be found), and TrustedPaths (for authorization).
Admittedly, speculation on my part... If someone knows better, please feel free to correct.
andrew_nao
« Reply #29 on: April 03, 2013, 10:51:21 AM »
Quote from: Kerry
:evil:
; <-- comments out the rest of the line so this wont work
