using System;
using System.Linq;
namespace PointKdTree
/// <summary>
/// Node of a Point3dTree
/// </summary>
public class TreeNode
/// <summary>
/// Creates a new instance of TreeNode
/// </summary>
/// <param name="value">The 3d point value of the node.</param>
public TreeNode(Point3d value) { this.Value = value; }
/// <summary>
/// Gets the value (Point3d) of the node.
/// </summary>
public Point3d Value { get; internal set; }
/// <summary>
/// Gets the parent node.
/// </summary>
public TreeNode Parent { get; internal set; }
/// <summary>
/// Gets the left child node.
/// </summary>
public TreeNode LeftChild { get; internal set; }
/// <summary>
/// Gets the right child node.
/// </summary>
public TreeNode RightChild { get; internal set; }
/// <summary>
/// Gets the depth of the node in tree.
/// </summary>
public int Depth { get; internal set; }
/// <summary>
/// Gets a value indicating if the current node is a LeftChild node.
/// </summary>
public bool IsLeft { get; internal set; }
/// <summary>
/// Provides methods to organize 3d points in a Kd tree structure to speed up the search of neighbours.
/// A boolean constructor parameter (ignoreZ) indicates if the resulting Kd tree is a 3d tree or a 2d tree.
/// Use ignoreZ = true if all points in the input collection lie on a plane parallel to XY
/// or if the points have to be considered as projected on the XY plane.
/// </summary>
public class Point3dTree
#region Private fields
private int dimension;
private int parallelDepth;
private bool ignoreZ;
private Func<Point3d, Point3d, double> sqrDist;
#endregion
#region Constructor
/// <summary>
/// Creates an new instance of Point3dTree.
/// </summary>
/// <param name="points">The Point3d collection to fill the tree.</param>
/// <param name="ignoreZ">A value indicating if the Z coordinate of points is ignored
/// (as if all points were projected to the XY plane).</param>
public Point3dTree(IEnumerable<Point3d> points, bool ignoreZ = false)
if (points == null)
throw new ArgumentNullException
("points"); this.ignoreZ = ignoreZ;
this.dimension = ignoreZ ? 2 : 3;
if (ignoreZ)
this.sqrDist = SqrDistance2d;
else
this.sqrDist = SqrDistance3d;
int numProc = System.Environment.ProcessorCount;
this.parallelDepth = -1;
while (numProc >> ++this.parallelDepth > 1) ;
Point3d[] pts = points.Distinct().ToArray();
this.Root = Create(pts, 0, null, false);
#endregion
#region Public properties
/// <summary>
/// Gets the root node of the tree.
/// </summary>
public TreeNode Root { get; private set; }
#endregion
#region Public methods
/// <summary>
/// Gets the nearest neighbour.
/// </summary>
/// <param name="point">The point from which search the nearest neighbour.</param>
/// <returns>The nearest point in the collection from the specified one.</returns>
public Point3d NearestNeighbour(Point3d point)
return GetNeighbour(point, this.Root, this.Root.Value, double.MaxValue);
/// <summary>
/// Gets the neighbours within the specified distance.
/// </summary>
/// <param name="point">The point from which search the nearest neighbours.</param>
/// <param name="radius">The distance in which collect the neighbours.</param>
/// <returns>The points which distance from the specified point is less or equal to the specified distance.</returns>
public Point3dCollection NearestNeighbours(Point3d point, double radius)
Point3dCollection points
= new Point3dCollection
(); GetNeighboursAtDistance(point, radius * radius, this.Root, points);
return points;
/// <summary>
/// Gets the given number of nearest neighbours.
/// </summary>
/// <param name="number">The number of points to collect.</param>
/// <returns>The n nearest neighbours of the specified point.</returns>
public Point3dCollection NearestNeighbours(Point3d point, int number)
List
<Tuple
<double, Point3d
>> pairs
= new List
<Tuple
<double, Point3d
>>(number
); GetKNeighbours(point, number, this.Root, pairs);
(); for (int i = 0; i < pairs.Count; i++)
points.Add(pairs[i].Item2);
return points;
/// <summary>
/// Gets the points in a range.
/// </summary>
/// <param name="pt1">The first corner of range.</param>
/// <param name="pt2">The opposite corner of the range.</param>
/// <returns>All points within the box.</returns>
public Point3dCollection BoxedRange(Point3d pt1, Point3d pt2)
Point3d lowerLeft
= new Point3d
( Math.Min(pt1.X, pt2.X), Math.Min(pt1.Y, pt2.Y), Math.Min(pt1.Z, pt2.Z));
Point3d upperRight
= new Point3d
( Math.Max(pt1.X, pt2.X), Math.Max(pt1.Y, pt2.Y), Math.Max(pt1.Z, pt2.Z));
(); FindRange(lowerLeft, upperRight, this.Root, points);
return points;
/// <summary>
/// Gets all the pairs of points which distance is less or equal than the specified distance.
/// </summary>
/// <param name="radius">The maximum distance between two points. </param>
/// <returns>The pairs of points which distance is less or equal than the specified distance.</returns>
public List<Tuple<Point3d, Point3d>> ConnectAll(double radius)
List
<Tuple
<Point3d, Point3d
>> connexions
= new List
<Tuple
<Point3d, Point3d
>>(); GetConnexions(this.Root, radius * radius, connexions);
return connexions;
#endregion
#region Private methods
private TreeNode Create(Point3d[] points, int depth, TreeNode parent, bool isLeft)
int length = points.Length;
if (length == 0) return null;
int d = depth % this.dimension;
Point3d median = points.QuickSelectMedian((p1, p2) => p1[d].CompareTo(p2[d]));
TreeNode node
= new TreeNode
(median
); node.Depth = depth;
node.Parent = parent;
node.IsLeft = isLeft;
int mid = length / 2;
int rlen = length - mid - 1;
Point3d
[] left
= new Point3d
[mid
]; Point3d
[] right
= new Point3d
[rlen
]; Array.Copy(points, 0, left, 0, mid);
Array.Copy(points, mid + 1, right, 0, rlen);
if (depth < this.parallelDepth)
System.Threading.Tasks.Parallel.Invoke(
() => node.LeftChild = Create(left, depth + 1, node, true),
() => node.RightChild = Create(right, depth + 1, node, false)
else
node.LeftChild = Create(left, depth + 1, node, true);
node.RightChild = Create(right, depth + 1, node, false);
return node;
private Point3d GetNeighbour(Point3d center, TreeNode node, Point3d currentBest, double bestDist)
if (node == null)
return currentBest;
Point3d current = node.Value;
int d = node.Depth % this.dimension;
double coordCen = center[d];
double coordCur = current[d];
double dist = this.sqrDist(center, current);
if (dist >= 0.0 && dist < bestDist)
currentBest = current;
bestDist = dist;
dist = coordCen - coordCur;
if (bestDist < dist * dist)
currentBest = GetNeighbour(
center, coordCen < coordCur ? node.LeftChild : node.RightChild, currentBest, bestDist);
bestDist = this.sqrDist(center, currentBest);
else
currentBest = GetNeighbour(center, node.LeftChild, currentBest, bestDist);
currentBest = GetNeighbour(center, node.RightChild, currentBest, bestDist);
return currentBest;
private void GetNeighboursAtDistance(Point3d center, double radius, TreeNode node, Point3dCollection points)
if (node == null) return;
if (dist <= radius)
points.Add(current);
if (dist * dist > radius)
if (coordCen < coordCur)
GetNeighboursAtDistance(center, radius, node.LeftChild, points);
else
GetNeighboursAtDistance(center, radius, node.RightChild, points);
else
private void GetKNeighbours(Point3d center, int number, TreeNode node, List<Tuple<double, Point3d>> pairs)
int cnt = pairs.Count;
if (cnt == 0)
pairs
.Add(new Tuple
<double, Point3d
>(dist, current
else if (cnt < number)
if (dist > pairs[0].Item1)
pairs
.Insert(0,
new Tuple
<double, Point3d
>(dist, current
else
pairs
.Add(new Tuple
<double, Point3d
>(dist, current
else if (dist < pairs[0].Item1)
pairs
[0] = new Tuple
<double, Point3d
>(dist, current
); pairs.Sort((p1, p2) => p2.Item1.CompareTo(p1.Item1));
if (dist * dist > pairs[0].Item1)
GetKNeighbours(center, number, node.LeftChild, pairs);
else
GetKNeighbours(center, number, node.RightChild, pairs);
else
private void FindRange(Point3d lowerLeft, Point3d upperRight, TreeNode node, Point3dCollection points)
if (node == null)
return;
if (ignoreZ)
if (current.X >= lowerLeft.X && current.X <= upperRight.X &&
current.Y >= lowerLeft.Y && current.Y <= upperRight.Y)
else
current.Y >= lowerLeft.Y && current.Y <= upperRight.Y &&
current.Z >= lowerLeft.Z && current.Z <= upperRight.Z)
if (upperRight[d] < current[d])
FindRange(lowerLeft, upperRight, node.LeftChild, points);
else if (lowerLeft[d] > current[d])
FindRange(lowerLeft, upperRight, node.RightChild, points);
else
private void GetConnexions(TreeNode node, double radius, List<Tuple<Point3d, Point3d>> connexions)
(); Point3d center = node.Value;
if (ignoreZ)
GetRightParentsNeighbours(center, node, radius, points);
for (int i = 0; i < points.Count; i++)
connexions
.Add(new Tuple
<Point3d, Point3d
>(center, points
[i
GetConnexions(node.LeftChild, radius, connexions);
GetConnexions(node.RightChild, radius, connexions);
private void GetRightParentsNeighbours(Point3d center, TreeNode node, double radius, Point3dCollection points)
TreeNode parent = GetRightParent(node);
if (parent == null) return;
int d = parent.Depth % this.dimension;
double dist = center[d] - parent.Value[d];
if (dist * dist <= radius)
GetNeighboursAtDistance(center, radius, parent.RightChild, points);
GetRightParentsNeighbours(center, parent, radius, points);
private TreeNode GetRightParent(TreeNode node)
TreeNode parent = node.Parent;
if (parent == null) return null;
if (node.IsLeft) return parent;
return GetRightParent(parent);
private double SqrDistance2d(Point3d p1, Point3d p2)
return (p1.X - p2.X) * (p1.X - p2.X) +
(p1.Y - p2.Y) * (p1.Y - p2.Y);
private double SqrDistance3d(Point3d p1, Point3d p2)
(p1.Y - p2.Y) * (p1.Y - p2.Y) +
(p1.Z - p2.Z) * (p1.Z - p2.Z);
#endregion
static class Extensions
// Credit: Tony Tanzillo
// http://www.theswamp.org/index.php?topic=44312.msg495808#msg495808
public static T QuickSelectMedian<T>(this T[] items, Comparison<T> compare)
int l = items.Length;
int k = l / 2;
if (items == null || l == 0)
throw new ArgumentException
("array"); int from = 0;
int to = l - 1;
while (from < to)
int r = from;
int w = to;
T current = items[(r + w) / 2];
while (r < w)
if (compare(items[r], current) > -1)
var tmp = items[w];
items[w] = items[r];
items[r] = tmp;
w--;
else
r++;
if (compare(items[r], current) > 0)
r--;
if (k <= r)
to = r;
else
from = r + 1;
return items[k];
