Author Topic: In need of a handout. Please.  (Read 11842 times)
daron
« on: March 17, 2005, 09:18:51 AM »
I am using a program in autocad that the original creator not only ecrypted the file but didn't collect any variables to return to their original state. What I'm in need of is an event module that collects the current layer when a lisp is called and restores that layer when the lisp is ended or cancelled. Will someone please throw out a bone with some meat on it. Thanks.
« Reply #1 on: March 17, 2005, 09:24:11 AM »
Could you wrap it ?
defun new-command
trap variables
call old-defunct-crappy0command
restore vars'
David Hall
  • Automatic Duh Generator
« Reply #2 on: March 17, 2005, 10:12:28 AM »
can you un-encrypt it?, also, what does it do, can we replicate it fairly easily
daron
« Reply #3 on: March 17, 2005, 10:48:53 AM »
I have gotten it unencrypted. There are a bunch of functions without a c: prompt and a bunch of code without a defun. It's a HUGE file. My problem is I'm not sure about encryption. How does autocad differentiate between an encrypted file and an unencrypted file or does that matter? I'm in process of creating a whole new program for this job, but it's a slow process. I just was hoping for a bandage for what I'm currently using.
Kerry, what you mention about the wrapping it? Isn't that what beginlisp and endlisp / cancellisp do? It's the beginLisp event that I'm not sure how to write. It'd be nice if the event could be fired anytime any lisp is called.
« Reply #4 on: March 17, 2005, 11:05:56 AM »
I don't mean to be a snot, but decrypting a program? Generally speaking this is a no no even though it's easy to do. Can you get the original source code from the author?
daron
« Reply #5 on: March 17, 2005, 11:16:48 AM »
I don't plan to update or even take from the original code. I just want something to keep it from setting me to layer 0 when I think I'm on a different layer.
« Reply #6 on: March 17, 2005, 11:20:04 AM »
Am I oversimplifying it by suggesting (command ".layerp")?
daron
« Reply #7 on: March 17, 2005, 11:21:19 AM »
Where? Yes. I don't care what the previous layer was, I just want to not be left on a layer I wasn't on. Why can't people who charge for code write code that plays nice?
« Reply #8 on: March 17, 2005, 11:21:46 AM »
After?
daron
« Reply #9 on: March 17, 2005, 11:24:32 AM »
Was in process of editing last post as you posted. See previous post.
« Reply #10 on: March 17, 2005, 11:26:11 AM »
Charging for code does not a professional make?
daron
« Reply #11 on: March 17, 2005, 11:39:25 AM »
Very true. Can a vba wrapper be created for this problem?
« Reply #12 on: March 17, 2005, 11:48:47 AM »
I was under the impression it was a lisp program?
Perhaps something like ...
(defun c:Wrap ( / vars )
    (setq vars
        (mapcar
           '(lambda (varname) (cons varname (getvar varname)))
           '("cmdecho" "clayer" "cecolor" "celtype")
    (c:CallTheOffendingProgram)
    (foreach pair vars
        (vl-catch-all-apply
           '(lambda ()
                (setvar (car pair) (cdr pair))
« Reply #13 on: March 17, 2005, 12:09:54 PM »
If the code runs on load you could do something like this ...
    (setq vars
        (mapcar
    (load "TheOffendingProgram" (princ "The load failed."))
    (foreach pair vars
        (vl-catch-all-apply
           '(lambda ()
daron
« Reply #14 on: March 17, 2005, 12:12:41 PM »
It is a lisp program that is the offender, but I was under the impression that vba could handle events better than lisp. Would I have to know each lisp name to watch for? Nice code by the way.
