Author Topic: When do objects actually get added to the database?  (Read 1573 times)
jlatimer11
  • Mosquito
« on: March 21, 2013, 02:05:59 PM »
I'm having an issue that I can't seem to figure out.
Before a form loads I take objects on layers and convert them to polylines. After user input on a form I loop through each layer and offset the polylines.
The issue I'm having is that occasionally some objects are not offset. There is no conditional statements, it's literally select polylines and offset. The number of objects in the selection set is less than the number of items on the layer.
So I'm wondering: Is there a specific instance where objects are committed to the database? Or, is there a way to force the database to update?
TheMaster
Re: When do objects actually get added to the database?
« Reply #1 on: March 21, 2013, 11:21:28 PM »
You haven't shown any code, and it's difficult to assume what your code does and/or how it does what it does.
The answer to the very general question you're asking, depends on too many variables that aren't known without seeing or knowing something about the code and what it does, so there's no simple answer to it.
jlatimer11
  • Mosquito
« Reply #2 on: March 22, 2013, 10:31:23 AM »
I didn't post the code because there was a ton of it, but since it is needed I'll post it.
Pre-Form Load:
    <CommandMethod("bsr")> _
Public Sub bsr()
Dim myDB As DatabaseServices.Database
        Dim myDWG As ApplicationServices.Document
        Dim myEd As EditorInput.Editor
        Dim myTransMan As DatabaseServices.TransactionManager
        Dim myTrans As DatabaseServices.Transaction
        Dim bsrlay As New ArrayList
        Dim myBTR As BlockTableRecord
        Dim myBT As BlockTable
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myDB = myDWG.Database
        myEd = myDWG.Editor
        myTransMan = myDB.TransactionManager
        myTrans = myTransMan.StartTransaction
        Using acLckDoc As DocumentLock = myDWG.LockDocument()
            myBT = myDWG.Database.BlockTableId.GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
            myBTR = myBT(Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.ModelSpace).GetObject(Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite)
            makePalletPline(myDWG, myDB, myTrans, myBTR, False)
        End Using
        myTrans.Commit()
        myTrans.Dispose()
        Dim form1 As New bs_recesses
        form1.Show()
    End Sub
Public Sub makePalletPline(ByVal mydwg As Document, ByVal mydb As Database, ByVal mytrans As Transaction, ByVal myBTR As BlockTableRecord)
        Dim pb As ArrayList = getBoundsByLayer(mydwg, mydb, "00-PLATE")
        Dim minpt As Point3d = New Point3d(pb(0) - 0.01, pb(1) - 0.01, 0)
        Dim maxpt As Point3d = New Point3d(pb(2) + 0.01, pb(3) + 0.01, 0)
        Dim dlays As ArrayList = getLayersByBounds(mydwg, mydb, minpt, maxpt)
        For Each lyr As String In dlays
            Dim objidcoll As ObjectIdCollection = makePlinebyLayer(lyr, mydwg, myBTR)
        Next
    End Sub
Public Function makePlinebyLayer(ByVal layername As String, ByVal myDWG As Document, ByVal myBTR As BlockTableRecord)
        Dim PSG As PolylineSegmentCollection = New PolylineSegmentCollection
        Dim ents As New ArrayList
        Dim segCol As PolylineSegmentCollection = New PolylineSegmentCollection
        Dim segments As DBObjectCollection = New DBObjectCollection
        Dim mySS As Autodesk.AutoCAD.EditorInput.SelectionSet = Nothing
        Dim myPSR As PromptSelectionResult = Nothing
        Dim myTV(0) As DatabaseServices.TypedValue
        myTV(0) = New DatabaseServices.TypedValue(DatabaseServices.DxfCode.LayerName, layername)
        Dim myFilter As New EditorInput.SelectionFilter(myTV)
        Dim myObjIds As DatabaseServices.ObjectIdCollection = Nothing
        Dim entinfo As New ArrayList
        Dim myEnt As DatabaseServices.Entity
        Dim retVal As ObjectIdCollection = New ObjectIdCollection
        Using myTrans As Transaction = myDWG.Database.TransactionManager.StartTransaction()
            myPSR = myDWG.Editor.SelectAll(myFilter)
            If Not IsNothing(myPSR.Value) Then
                mySS = myPSR.Value
                myObjIds = New DatabaseServices.ObjectIdCollection(mySS.GetObjectIds)
                For Each myObjId In myObjIds
                    myEnt = myObjId.GetObject(DatabaseServices.OpenMode.ForWrite)
                    segments.Add(myEnt)
                Next
            End If
            'Borrowed from TheSwamp.org
            Dim i As Integer = 0
            Do While (i < segments.Count)
                Dim obj As DBObject = segments(i)
                Select Case (obj.GetType.Name)
                    Case "Line"
                        Dim line As Line = CType(obj, Line)
                        pt = line.StartPoint
                        Dim ls As LineSegment2d = New LineSegment2d(New Point2d(pt.X, pt.Y), New Point2d(line.EndPoint.X, line.EndPoint.Y))
                        segCol.Add(New PolylineSegment(ls))
                    Case "Arc"
                        Dim arc As Arc = CType(obj, Arc)
                        pt = arc.StartPoint
                        Dim midPT As Point3d = arc.GetPointAtParameter(((arc.EndParam + arc.StartParam) / 2))
                        Dim ca As CircularArc2d = New CircularArc2d(New Point2d(pt.X, pt.Y), New Point2d(midPT.X, midPT.Y), _
        New Point2d(arc.EndPoint.X, arc.EndPoint.Y))
                        segCol.Add(New PolylineSegment(ca))
                    Case "Circle"
                        Dim c As Circle = CType(obj, Circle)
                        pt = c.Center
                        segCol.AddRange(New PolylineSegmentCollection(c))
                    Case "Ellipse"
                        Dim el As Ellipse = CType(obj, Ellipse)
                        pt = el.Center
                        segCol.AddRange(New PolylineSegmentCollection(el))
                    Case "Spline"
                End Select
                obj.Dispose()
                i = (i + 1)
            Loop
            For Each psc As PolylineSegmentCollection In segCol.Join
                Dim pl As Polyline = psc.ToPolyline
                pl.Layer = layername
                retVal.Add(myBTR.AppendEntity(pl))
                myTrans.AddNewlyCreatedDBObject(pl, True)
            Next
            myTrans.Commit()
        End Using
        Return retVal
      End Function
After User Data Input on Form:
    Private Sub Button2_Click(ByVal sender As System.Object, ByVal ea As System.EventArgs) Handles Button2.Click
        Dim minfloor As Decimal = CDec(TextBox6.Text)
        Dim myDWG As Autodesk.AutoCAD.ApplicationServices.Document
        myDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myEd = myDWG.Editor
            Dim xmin As Point3d = New Point3d(-10,-10,0)
            Dim xmax As Point3d = New Point3d(10,10,0)
            Dim newlayname As String = "OFFSET"
                    For Each play As String In Listbox2.Items
                            Dim xi As ArrayList = selitemXing(play, myTrans, myTransMan, myDB, myEd, myDWG, xmin, xmax) 'WHERE THE PROBLEM HAPPENS. RETURNS A NUMBER LESS THAN THE NUMBER OF OBJECTS
                            For Each e As Entity In xi
                                If TypeOf e Is Polyline Then
                                    Dim dbobj As ObjectIdCollection = Tools.Offset(e.ObjectId, (-.010))
                                ElseIf TypeOf e Is Circle Then
                                    Dim mycirc As Circle = e
                                    Dim mycirc2 As Circle = Nothing
                                    mycirc2 = e.Clone
                                    mycirc2.SetDatabaseDefaults()
                                    mycirc2.Layer = newlayname
                                    mycirc2.Diameter = mycirc.Diameter + (.020)
                                    myBTR.AppendEntity(mycirc2)
                                    myTrans.AddNewlyCreatedDBObject(mycirc2, True)
                                End If
                            Next
                            xi.Clear()
                        End If
                    Next
                Next
        myTrans.Commit()
        myTrans.Dispose()
    End Sub
Public Function selitemXing(ByVal layername As String, ByVal mytrans As DatabaseServices.Transaction, _
                 ByVal mytransman As DatabaseServices.TransactionManager, _
               ByVal myDB As DatabaseServices.Database, ByVal myED As EditorInput.Editor, _
               ByVal myDWG As ApplicationServices.Document, ByVal startpoint As Point3d, ByVal endpoint As Point3d) As ArrayList
        Dim myPSR As EditorInput.PromptSelectionResult
        Dim mySS As EditorInput.SelectionSet
        myPSR = myED.SelectCrossingWindow(startpoint, endpoint, myFilter)
            mySS = myPSR.Value
                myEnt = myObjId.GetObject(DatabaseServices.OpenMode.ForRead)
                entinfo.Add(myEnt)
                i = i + 1
            Next
        End If
        Return entinfo
    End Function
Jeff H
« Reply #3 on: March 22, 2013, 11:00:07 AM »
You might want to think about refactor that a bit, but looking quickly I saw where you said selitemXing was returning a number less than the total number and probably has to do with SelectCrossingWindow.
Are all entities visible on screen?
Might want to take a different approach.
