Author Topic: What is the best way to draw a Single-Line text with assignd font.  (Read 2641 times)
waterharbin
Hi.
I want to create a funtion that draw a Single-Line text with assigned font. So,everytime I want to draw some text, I just call this function. Here is what I get.
Public Shared Function AddTextArial(ByVal Location As Point3d, ByVal TextString As String, ByVal Height As Double) As ObjectId
        Try
            '' Get the current document and database
            Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
            Dim acCurDb As Database = acDoc.Database
            'Set the font
            '' Start a transaction
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                '' Open the current text style for write
                Dim acTextStyleTblRec As TextStyleTableRecord
                acTextStyleTblRec = acTrans.GetObject(acCurDb.Textstyle, _
                                                      OpenMode.ForWrite)
                '' Get the current font settings
                Dim acFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
                acFont = acTextStyleTblRec.Font
                '' Update the text style's typeface with "Arial"
                Dim acNewFont As Autodesk.AutoCAD.GraphicsInterface.FontDescriptor
                acNewFont = New  _
                  Autodesk.AutoCAD.GraphicsInterface.FontDescriptor("Arial", False, False, acFont.CharacterSet, acFont.PitchAndFamily)
                acTextStyleTblRec.Font = acNewFont
                acDoc.Editor.Regen()
                '' Save the changes and dispose of the transaction
                acTrans.Commit()
            End Using
            'Font is set
            'draw the text
            Dim ent As New DBText()
            ent.Position = Location
            ent.TextString = TextString
            ent.Height = Height
            Dim entId As ObjectId = AppendEntity(ent)
            Return entId
        Catch ex As Exception
            Dim NullId As ObjectId = ObjectId.Null
            Return NullId
        End Try
    End Function
I overload the AppendEntity to return the ObjectId of the text. This is how I do it, I do not want to modify my AppendEntity.
Public Shared Function AppendEntity(ByVal ent As Entity) As ObjectId
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Using trans As Transaction = db.TransactionManager.StartTransaction
            Dim bt As BlockTable = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
            Dim btr As BlockTableRecord = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            entId = btr.AppendEntity(ent)
            trans.AddNewlyCreatedDBObject(ent, True)
            trans.Commit()
        End Using
        Return entId
    End Function
But It seems that I will have to set the font everytime I call this function. How to improve?
« Last Edit: March 14, 2013, 05:27:20 AM by 闻仲 »
WILL HATCH
Re: What is the best way to draw a Single-Line text with assignd font.
« Reply #1 on: March 14, 2013, 09:17:12 AM »
by changing the current text style you'll also change all instances of text which use it... create a new one if required
waterharbin
« Reply #2 on: March 15, 2013, 09:52:28 AM »
Hi,Will.
How to create one TextStyle, and set it current? Please give me some codes!
WILL HATCH
« Reply #3 on: March 15, 2013, 12:38:49 PM »
I've never created one via .NET sorry.  I just know it's a hard pointer from text objects to the TextStyleTableRecord, so changing the style def will change all instances of text using it (much like a block def)
n.yuan
« Reply #4 on: March 15, 2013, 03:09:27 PM »
Hi,Will.
if you had searched this forum, you would have easily found this posted question and some smaple code:
http://www.theswamp.org/index.php?topic=39214.msg445047#msg445047
