Author Topic: Dynamic Block Copy & Paste Problem  (Read 9554 times)
MUQTAR
« on: March 14, 2013, 04:19:18 AM »
I make some dynamic blocks with rotate action, and i place them in drawing so many places with different angle now my problem is when those blocks i m trying to copy to other drawing, first thing they not coming as a dynamic blocks and those all blocks angles are disturbed.
please if any one knows how to copy paste properly waiting for your helpful comments
Thanks in advance.
Nibster
Re: Dynamic Block Copy & Paste Problem
« Reply #1 on: March 15, 2013, 07:57:31 AM »
did you use a completely new name for your new Dblock or did you upgrade an existing one that is already existing in the destination file?
MUQTAR
« Reply #2 on: March 15, 2013, 01:08:24 PM »
thanks for comments and sorry for late reply,
i upgrade my existing block to dynamic block and copy to other drawing.
Nibster
« Reply #3 on: March 15, 2013, 01:56:34 PM »
no apology needed.
That might be the issue.  Does everything work as desired if you paste the blocks into a fresh new drawing?
« Reply #4 on: March 15, 2013, 02:09:56 PM »
I have seen the same thing happen and I think workaround and emphasis on around
-WBLOCK the selected BlockReferences
-XATTACH the drawing
-Set BINDTYPE = 1
-Bind with insert option
MUQTAR
« Reply #5 on: March 16, 2013, 02:26:32 AM »
-Set BINDTYPE = 1
hi jeef H thanks for your helpful comments, using XATTACH and BINDTYPE=0 its done simply.
thanks again
HasanCAD
« Reply #6 on: March 16, 2013, 07:43:39 AM »
- Be sure that X,Y & Z scale factor are the same -by retyping- means retype 1 for X, Y & Z
