Author Topic: Do you have ideas for land development calculator  (Read 2409 times)
nobody
  • .net stuff
« on: March 09, 2013, 07:26:47 PM »
I'm building a simple application to have various calculations for land development / design.  I plan on including manning pipe calcs, earthwork cut/fill calc, vertical curves and roadway transitions. Anyone else have ideas that would be good for this?
Thanks!
huiz
  • Certified Prof C3D
Re: Do you have ideas for land development calculator
« Reply #1 on: March 10, 2013, 03:16:42 AM »
what does 'simple' mean?
nobody
  • .net stuff
« Reply #2 on: March 10, 2013, 07:31:07 AM »
Just basic algebraic equations.  I'm not a Lee Mac (aka math genius)...my major was in computer graphics lol.  Typically we calc vertical curves based on K value, easy to add.... earthwork will just be entering an area and cut/fill height to get a basic / quick estimated volume, the manning pipe calcs have been reinvented a million times on the net so I'm just duplicating the tools I like... and the transitions for roads are fairly straight forward in our area as well.
« Last Edit: March 10, 2013, 07:35:19 AM by Alien »
huiz
« Reply #3 on: March 10, 2013, 08:29:53 AM »
You do not use Civil3D? If you try to program all those things you might better buy a Civil3D and use that.
At the moment I work on an application that does surface creation, volume calculating, sections of surfaces, profiles from 3D polylines, and so on. It is quite a lot of work, especially the math to calcultate intersecting triangles and the height difference. The application is meant for BricsCAD users and AutoCAD users that don't need a full Civil3D.
You can't create all these things in a few hours, you need weeks or months of develop time. There are also cheap or free earthwork programs you can use. Maybe that is an option?
nobody
  • .net stuff
« Reply #4 on: March 10, 2013, 09:14:12 AM »
gotcha.... we have civil 3d. I'm just creating quick tools to help design sites.
huiz
« Reply #5 on: March 10, 2013, 12:12:09 PM »
Well, explore the Civil3D API to see what functions you can use. There is a lot of potential in it. A lot of the math can be done with that.
