.... excellent. I have no use for Dictionaries, at this time, so my understanding is essentially complete.
Your routine, I do not need text, so it got shorter. The end result needs to be a rough opening in a wall,
going from 2d to 3d. I extrude walls UP in plan view, but need to create the openings perpendicular to
WCS. Actually, entmakex is going to be handy. I can create a list of enames for the lwpolylines I create,
and pass the list on to the EXTRUDE command.
Which brings up the next thing. All I know to do to make primitive solids is EXTRUDE, and it works.
(command "extrude" ename ......
But can I entmake a solid?
I hate using the command command.
thanks.
