Author Topic: offset code it s ok or any modification this code  (Read 1899 times)
Sam
« on: March 04, 2013, 02:24:22 AM »
Dear sir,
please see this offset code it s ok or any modification this code
  1. (defun c:150 () (command "offset" "150"))
  2. (defun c:230 () (command "offset" "230"))
  3. (defun c:100 () (command "offset" "100"))
  4.
or
  1. (defun c:150    () (command "Offset" 150 pause)(princ))
What is difference between below code
  1. (defun c:150 () (command "offset" "150") (princ))
  2. (defun c:150 () (command "offset" "150"))
  3. (defun c:150 () (command "Offset" 150 pause)
  4.
« Last Edit: March 04, 2013, 09:05:21 AM by Sam »
Every time we waste electricity, we put our planet's future in the dark. Let's turn around our attiude and start saving power and our planet, before it's too late
http://www.theswamp.org/donate.html
roy_043
  • BricsCAD 18
Re: offset code it s ok or any modification this code
« Reply #1 on: March 04, 2013, 10:32:27 AM »
In all these examples the command continues beyond the scope of the function. This is not good programming practice. My suggestions:
  1. (defun c:150 ()
  2.   (command "_.offset" 150)
  3.   (while (> (getvar 'cmdactive) 0)
  4.     (command pause)
  5.   )
  6.   (princ)
  7. )
  1. (defun c:150 ()
  2.   (command "_.offset" 150 pause pause "")
  3.   (princ)
  4. )
Sam
« Reply #2 on: March 04, 2013, 11:42:06 PM »
  1. (defun c:150 ()
  4.     (command pause)
  5.   )
  6.   (princ)
  7. )
  1. (defun c:150 ()
  3.   (princ)
  4. )
Dear Sir,
Thx for guidance
Thx for Reply
Sam
« Reply #3 on: March 05, 2013, 01:54:24 AM »
Dear Sir,
i am combing of varies offset this code ok or any suggestion
  1. (defun c:100 ()
  2.   (command "_.offset" 100)
  3.   (defun c:150 ()
  4.     (command "_.offset" 150)
  5.     (defun c:230 ()
  6.       (command "_.offset" 230)
  7.       (while (> (getvar 'cmdactive) 0)
  8.         (command pause)
  9.       )
  10.       (princ)
  11.     )
  12.   )
  13. )
roy_043
  • BricsCAD 18
« Reply #4 on: March 05, 2013, 03:04:56 AM »
If you test your code in a new drawing you will find that the nested functions only become available after their parent functions have been called. This means that you have to use the c:100 function at least once for the c:150 function to become available. And the c:150 function must be called for the c:230 function to become available. And of the three functions only c:230 will behave properly.
The question is what are you trying to do? You should not nest functions without a good reason.
If you want to use an 'offset template' function, consider this example:
  1. (defun OffsetTemplate (dist)
  2.   (command "_.offset" dist)
  4.     (command pause)
  5.   )
  6. )
  7.
  8. (defun c:100 () (OffsetTemplate 100) (princ))
  9. (defun c:150 () (OffsetTemplate 150) (princ))
  10. (defun c:230 () (OffsetTemplate 230) (princ))
Sam
« Reply #5 on: March 05, 2013, 05:12:42 AM »
  4.     (command pause)
  5.   )
  6. )
  7.
[/quote]
Dear Sir,
Thx for help
i am study
