on that note, does anybody know a fast way to get a preview image without using autocad? I did some looking into it but didn't find a solid quick solution. I had to wait until the tooltip is opening to load the images into the tool tip without a noticeable lag when a directory was expanded as a work around.
Cheers
http://www.theswamp.org/index.php?topic=30985.0
Thank you! I knew I had seen something like that before.
Another function I'd like to add is something similar to the click-drag selection in windows explorer (similar to below), but I'm not sure how to do this as I'm using a custom treeview which inherits System.Windows.Controls.TreeView which doesn't offer any single click event to manage the drag. I'm sure if I was a pro I'd know how to add new events to the class but I'm a little stumped here.
Cheers
