Author Topic: Xdata vs Ldata  (Read 11141 times)
ribarm
  • Marko Ribar, architect
Xdata vs Ldata
« on: March 01, 2013, 06:22:36 AM »
Somewhere I read that xdata is more reliable than ldata... Can't find where I read this... Some thoughts if you know...
Thanks, M.R.
M.R. on Youtube
togores
Re: Xdata vs Ldata
« Reply #1 on: March 01, 2013, 06:40:21 AM »
Hi Marko, I quote here some considerations on this subject from my book "AutoCAD expert's Visual LISP", Chapter 23:
ActiveX Functions for XDATA, XRECORD and Dictionaries.
XDATA, XRECORD and Dictionaries  emerged in the pre-ActiveX AutoCAD era. Although there are equivalent ActiveX methods and properties, processing from Visual LISP functions has no disadvantages. Quite the contrary, the ease with which LISP creates and processes data lists represents an advantage over ActiveX methods that require packing data as safearrays.
But there is a simpler set of ActiveX dictionary functions. These dictionaries belong to a special type known as LDATA. We already used this format in the Chapter 1 Tutorial.
 LDATA functions can save a lot of programming effort.  In the following section we will summarize the use of these functions when dealing to storing non-graphical information in the drawing, with or without links to graphic entities.
23.5 LDATA Dictionaries.
We can distinguish between two different types of dictionary objects: the LDATA dictionary aimed at storing information in LISP format and dictionary objects composed by XRECORD entities in which information is managed using a DXF style coding. As we have seen, the XRECORD object dictionaries require considerable programming effort. But for LDATA dictionaries, Visual LISP provides a set of functions that ease their use.
Caution should be exercised when using this kind of object because the LDATA information for Release 2000 and above is not compatible with AutoCAD Release 14. If the drawing is saved in R14 drawing format information may be lost or corrupted. Although it's not likely today, a drawing to be used with such an old version should use XRECORD dictionaries. But everything is relative, since we know that XRECORD would be lost when using the drawing in a release prior to R13c4, and XDATA would only survive the round trip to Release 11, but not beyond it.
There is no specific function for the creation of LDATA dictionaries. Adding data will automatically create them. The dictionary can exist by itself in the drawing with a name that identifies it, but it can also be attached to any drawing object.
You can find more information in my blog http://lispexpert.blogspot.com/
Hope this helps...
« Last Edit: March 01, 2013, 06:43:39 AM by togores »
ribarm
Re: Xdata vs Ldata
« Reply #2 on: March 01, 2013, 07:34:59 AM »
Thanks, togores, though I have one direct question... How can I obtain list of all registered dictionary names registered through (vlax-ldata-put) function?
M.R. on Youtube
dgorsman
Re: Xdata vs Ldata
« Reply #3 on: March 01, 2013, 10:25:45 AM »
One thing I've noted with LDATA, is if a drawing with LDATA is opened and (vl-load-com) has *not* been called the proxy warning dialog will warn about VL data, similar to if a drawing has C3D or other proxy objects.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
ribarm
Re: Xdata vs Ldata
« Reply #4 on: March 01, 2013, 10:50:30 AM »
Yes, I've noticed that too...
M.R. on Youtube
togores
Re: Xdata vs Ldata
« Reply #5 on: March 01, 2013, 04:54:15 PM »
This is a bit complicated, as LDATA dictionaries may be "named" or can be assigned to an entity. If it is named, it will be included in the Named Object Dicionary:
_$ (vlax-ldata-put "TESTDICT" "DATA1" "THIS IS A TEST")
"THIS IS A TEST"
_$ (vlax-ldata-get "TESTDICT" "DATA1")
"THIS IS A TEST"
_$ (entget (namedobjdict))
((-1 . <Entity name: 7ffff7038c0>)
  (0 . "DICTIONARY")
  (330 . <Entity name: 0>)
  (5 . "C")
  (100 . "AcDbDictionary")
  (280 . 0)
  (281 . 1)
  (3 . "ACAD_CIP_PREVIOUS_PRODUCT_INFO")
  (350 . <Entity name: 7ffff7049e0>)
  (3 . "ACAD_COLOR")
  (350 . <Entity name: 7ffff703bb0>)
  (3 . "ACAD_DETAILVIEWSTYLE")
  (350 . <Entity name: 7ffff704a30>)
  (3 . "ACAD_GROUP")
  (350 . <Entity name: 7ffff7038d0>)
  (3 . "ACAD_LAYOUT")
  (350 . <Entity name: 7ffff7039a0>)
  (3 . "ACAD_MATERIAL")
  (350 . <Entity name: 7ffff703ba0>)
  (3 . "ACAD_MLEADERSTYLE")
  (350 . <Entity name: 7ffff704150>)
  (3 . "ACAD_MLINESTYLE")
  (350 . <Entity name: 7ffff703970>)
  (3 . "ACAD_PLOTSETTINGS")
  (350 . <Entity name: 7ffff703990>)
  (3 . "ACAD_PLOTSTYLENAME")
  (350 . <Entity name: 7ffff7038e0>)
  (3 . "ACAD_SCALELIST")
  (350 . <Entity name: 7ffff7040c0>)
  (3 . "ACAD_SECTIONVIEWSTYLE")
  (350 . <Entity name: 7ffff704a10>)
  (3 . "ACAD_TABLESTYLE")
  (350 . <Entity name: 7ffff703c60>)
  (3 . "ACAD_VISUALSTYLE")
  (350 . <Entity name: 7ffff703ef0>)
  (3 . "AcDbVariableDictionary")
  (350 . <Entity name: 7ffff703ae0>)
  (3 . "TESTDICT") ;; this is our dictionary
  (350 . <Entity name: 7ffff704b50>))
If assigned to an entity it will be included as its Extension Dictionary:
_$ (vlax-ldata-put (entlast) "ENTDATA1" "THIS IS ATTACHED TO A CIRCLE")
_$ (entget (entlast))
((-1 . <Entity name: 7ffff704be0>)
  (0 . "CIRCLE")
  (5 . "236")
  (102 . "{ACAD_XDICTIONARY")
  (360 . <Entity name: 7ffff704bf0>) ;; this ename can be used to get the extension dictionary
  (102 . "}")
  (330 . <Entity name: 7ffff7039f0>)
  (100 . "AcDbEntity")
  (67 . 0)
  (410 . "Model")
  (8 . "0")
  (100 . "AcDbCircle")
  (10 2328.9 2020.6 0.0)
  (40 . 178.42)
  (210 0.0 0.0 1.0))
_$ (entget (cdr (assoc 360 (entget (entlast)))))
((-1 . <Entity name: 7ffff704bf0>)
  (0 . "DICTIONARY")
  (330 . <Entity name: 7ffff704be0>)
  (5 . "237")
  (280 . 1)
  (281 . 1)
  (3 . "ENTDATA1") ;; this is our dictionary's name
  (360 . <Entity name: 7ffff704c00>))
In my acaddoc.lsp I include a call to (vla-load-com) as I use a lot of ActiveX functions in my code, so I don't get the warning message about ActiveX not being loaded.
But on a second thought, something against using LDATA would be that it is not compatible with AutoCAD for MAC. And it seem the future would point to a multiplatform application instead of Windows-only...
Re: Xdata vs Ldata
« Reply #6 on: March 01, 2013, 05:25:11 PM »
Note also that LData is stored usig VLO-VL entities, rather than XRECORD entities, as the following code demonstrates:
  1. (defun c:test ( )
  2.     (vlax-ldata-put "MyDict" "MyKey" "MyData")
  3.     (mapcar 'print (dictsearch (cdr (assoc -1 (dictsearch (namedobjdict) "MyDict"))) "MyKey"))
  4.     (princ)
  5. )
ribarm
Re: Xdata vs Ldata
« Reply #7 on: March 01, 2013, 05:45:22 PM »
It seems that, once they are stored (LDATA) it's pretty hard to remove them all in one shot - or I am wrong - there is something similar to this code I've used to remove XDATAs and their corresponding APPIDs :
  1. (defun c:remallregappids+Xdatas ( / ss app appnlst appea )
  2.   (setq ss (ssget "_X"))
  3.     (foreach app (cdr (assoc -3 (entget (vlax-vla-object->ename x) (list "*"))))
  4.       (entmod (list (cons -1 (vlax-vla-object->ename x)) (list -3 (list (car app)))))
  5.       (setq appnlst (cons (car app) appnlst))
  6.     )
  7.   )
  8.   (setq appnlst (acet-list-remove-duplicates appnlst nil))
  9.   (foreach appn appnlst
  10.     (setq appea (vlax-ename->vla-object (tblobjname "APPID" appn)))
  11.     (vla-delete appea)
  12.     (vlax-release-object appea)
  13.   )
  14.   (princ)
  15. )
  16. (defun c:rappX nil (c:remallregappids+Xdatas))
  17. (prompt "\nShortcut for c:remallregappids+Xdatas is c:rappX ; Start with : Command: rappX")
  18.
M.R. on Youtube
hermanm
Re: Xdata vs Ldata
« Reply #8 on: March 02, 2013, 02:29:30 PM »
One thing to keep in mind is accessibility of the data from other APIs.
I dimly recall a post by Tony T (who else?) showing how to access LDATA from .NET, but my memory may be faulty. There is no direct .NET interface to VLO-VL objects, AFAIK.
XDATA, clumsy as it is, is fully acccessible via .NET
ribarm
Re: Xdata vs Ldata
« Reply #9 on: March 03, 2013, 04:24:49 AM »
It seems that there is a way and for LDATA... If someone wants to remove them all, there is nothing you can do about it to prevent him/she from doing it...
  1. (defun c:remallLdata ( / d ed dn eddn edddn ss e el el360 el360360 )
  2.   (setq ed (entget d))
  3.   (setq ed (member (assoc 3 ed) ed))
  4.   (while ed
  5.     (setq dn (cdr (assoc 3 ed)))
  6.     (setq eddn (dictsearch d dn))
  7.     (setq eddn (member (assoc 3 eddn) eddn))
  8.     (while eddn
  9.       (if (assoc 350 eddn)
  10.         (progn
  11.           (setq edddn (entget (cdr (assoc 350 eddn))))
  12.           (if (and (eq (cdr (assoc 0 edddn)) "VLO-VL") (assoc 300 edddn))
  13.             (dictremove d dn)
  14.           )
  15.         )
  16.       )
  17.       (setq eddn (cddr eddn))
  18.     )
  19.     (setq ed (cddr ed))
  20.   )
  21.   (setq ss (ssget "_X"))
  22.     (setq e (vlax-vla-object->ename x))
  23.     (setq el (entget e))
  24.     (if (assoc 360 el)
  25.       (progn
  26.         (setq el360 (entget (cdr (assoc 360 el))))
  27.         (while (assoc 3 el360)
  28.           (setq el360360 (entget (cdr (assoc 360 el360))))
  29.           (if (and (eq (cdr (assoc 0 el360360)) "VLO-VL") (assoc 300 el360360))
  30.             (entdel (cdr (assoc -1 el360360)))
  31.           )
  32.           (setq el360 (entget (cdr (assoc -1 el360))))
  33.         )
  34.       )
  35.     )
  36.   )
  37.   (princ)
  38. )
  39.
So, these 2 codes with purging all objects can make dwg size smaller, but with less data... :-D
« Last Edit: March 03, 2013, 11:15:05 AM by ribarm »
M.R. on Youtube
Re: Xdata vs Ldata
« Reply #10 on: March 03, 2013, 08:32:02 AM »
Marko, you may find the dictnext function easier to use when iterating over dictionaries, e.g.:
  1. (defun c:remldata ( / dic ent enx lst nod xdc )
  2.     (setq nod (namedobjdict))
  3.     (while (setq dic (cdr (assoc -1 (dictnext nod (null dic)))))
  4.         (if (= "VLO-VL" (cdr (assoc 0 (dictnext dic t))))
  5.             (setq lst (cons dic lst))
  6.         )
  7.     )
  8.     (foreach ent lst (entdel ent))
  9.     (setq ent (entnext))
  10.     (while ent
  11.         (if (and
  12.                 (member '(102 . "{ACAD_XDICTIONARY") (setq enx (entget ent)))
  13.                 (setq xdc (cdr (assoc 360 enx)))
  14.                 (= "VLO-VL" (cdr (assoc 0 (dictnext xdc t))))
  15.             )
  16.             (entdel xdc)
  17.         )
  18.         (setq ent (entnext ent))
  19.     )
  20.     (princ)
  21. )
Though, I have never attempted to delete an Extension Dictionary, so I am unsure whether that part of the code is correct.
ribarm
Re: Xdata vs Ldata
« Reply #11 on: March 03, 2013, 08:43:55 AM »
I've changed little more my last code for remallLdata, as I didn't take in consideration multiple ldata-put to each single entity... Now it works as I wanted...
Thanks, Lee... Still my first question stands : What is better Xdata or Ldata and why?
M.R. on Youtube
Re: Xdata vs Ldata
« Reply #12 on: March 03, 2013, 10:40:13 AM »
Here's a quote from a post by Tony Tanzillo on the Autodesk Lisp forum, from back in 2004. I have never used LData based on this.
Quote from: Tony T
LDATA is just a way to 'encrypt' your data in a dictionary, using a custom object. In fact, in some circumstances (opening a file by double- clicking in explorer) you can see proxy notices when you open a file with LDATA. The only thing LDATA offers is that it preserves the original list structure, which is something that is useful only to entry level programmers. The disadvantages is that it is a way to lock your data up in a way that can potentially render it completely inaccessible, which is what happened when R14 drawings were migrated to AutoCAD 2000. You can use Dictionaries and XRecords to store anything you can store in LDATA and can access it via any API you might choose to use. In short, stay as far away from LDATA as you can possibly get.
Here's the link to the thread I found that in: http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/What-about-ldata/m-p/941043#M139521
« Last Edit: March 03, 2013, 10:43:47 AM by Jeff_M »
Re: Xdata vs Ldata
« Reply #13 on: March 03, 2013, 11:21:55 AM »
Are we not sufficiently beyond R14 that we no longer worry about that problem?
owenwengerd
Re: Xdata vs Ldata
« Reply #14 on: March 03, 2013, 12:26:19 PM »
The problem was not R14. The problem was that Autodesk changed the data format. We're most certainly not beyond that problem. Personally, I wouldn't touch ldata with a ten foot pole. There are a lot of potential pitfalls with ldata, and just no real benefit over xrecords.
