Author Topic: request Dictionary with DCL-listbox  (Read 2244 times)
cadplayer
« on: February 27, 2013, 06:14:59 AM »
Hello!
I have an idea, to set and request dictionaries from Autocad.database = forexample define a dictionary that haves project specify types. Have anybody an example to can write an dictionary which include a list ((0 . "projectname") (1 . "date") (2 . "props..")). I don´t know which Lispfunction would be intressting to do this. I think I need a read- and write function. How does it look like ?
« Last Edit: February 27, 2013, 07:47:57 AM by cadplayer »
Re: request Dictionary with DCL-listbox
« Reply #1 on: February 27, 2013, 08:07:45 AM »
cadplayer
« Reply #2 on: February 27, 2013, 08:26:26 AM »
I think different, it would be nice if I could save standard textblocks in dictionaries which I always use in my drawings and request them if I need...
irneb
« Reply #3 on: February 27, 2013, 08:34:14 AM »
For the rest why not use a Drawing Property? E.g. http://www.theswamp.org/index.php?topic=21308.0
Else if you're dead set on using dictionaries, then the base for dictionaries linked to the DWG as a whole is the ename returned by NamedObjDict. So you'd basically create a Dictionary (using entmake) to add it to that "overall" dictionary using DictAdd. Then for each of your values you'd create an XRecord and DictAdd those to the custom dictionary you created.
IMO the dictionary idea seems a lot more complex than simply working with custom dwg properties. And you don't get any benefit between the 2. Actually you can have attributes / text link to properties, but not to dictionaries. That would make your "standard" blocks a lot simpler too.
cadplayer
« Reply #5 on: February 27, 2013, 10:49:46 AM »
Fantastic ! I understand now how read and write dictionaries, but what is about if I have saved a own dictionary in a drawing and want to be change something...
(dictremove (namedobjdict) "DWGPROPS") ; erase only my dictionary
(dictadd (namedobjdict) "DWGPROPS" (entmakex xlist)) ; redifine my dictionary
Have I missed something?
kruuger
« Reply #7 on: February 27, 2013, 12:19:49 PM »
http://cad.pl/ftp/Pack/v1/CADPL-Pack-v1.lsp
go to DCT section. collection of dictionary function with sample.
k.
« Last Edit: February 27, 2013, 12:23:30 PM by kruuger »
cadplayer
« Reply #8 on: February 27, 2013, 01:33:40 PM »
Thanks for all great stuff, thats was exactly what I want have. Enough to read now :wink:
« Reply #9 on: February 27, 2013, 03:52:07 PM »
Homework  :-)
I bet you'd make a great librarian Alan !!
Just wanted to acknowledge your excellent continuing contribution.
Regards,
« Reply #10 on: February 27, 2013, 04:05:02 PM »
Well thank you Sir, kind of you to say.  :-D
