Author Topic: strange problem with events  (Read 7247 times)
Jeff H
Re: strange problem with events
« Reply #15 on: March 04, 2013, 03:14:35 PM »
In the BeginSave event have you tried checking DatabaseIOEventArgs.FileName and dropping out if file extension is 'sv$'?
TheMaster
« Reply #16 on: March 04, 2013, 03:19:33 PM »
after some day's of testing. I've came to a couple of things.
autocad 2009, no problems all works like it should.
autocad 2010, 2011, 2012 no problems all works like it should.
2013 works, until 1 document hits an autosave and the savehandlers are gone.
i know events have limitations, but it has been working for the last 5 years, why did it break in 2013.
the code hasn't changed much between the autocad versions.
Remember that this is not a full database app, i'm only doing a insert or update query to a sql database with 8 block attribute values.
there is no timing issue, or network delay.
i hope a fix is available, otherwise we will stay on 2012.
Most I know who are using customization have passed on AutoCAD 2013, because of many issues. That's what appens when new releases create more problems than they solve.
sybold
« Reply #17 on: March 04, 2013, 03:31:08 PM »
just tried it, same result. it magically gone
sybold
« Reply #18 on: March 04, 2013, 03:33:21 PM »
i've got a slim version running now with only printing savebegin and savecomplete in the commandline, not doing any other stuff. same problem.
Jeff H
« Reply #19 on: March 04, 2013, 03:58:39 PM »
In first example where does _Document variable come from, which Document is it pointing to?
How about posting a simple project that you can produce the problem with.
trembre
« Reply #20 on: March 04, 2013, 04:43:10 PM »
 I had the same issue - http://www.theswamp.org/index.php?topic=42961.msg481822#msg481822 - with AutoCAD 2011.
 The problem always arose using BeginSave when multiple drawings were open and an Autosave was fired off - for some reason the event handlers "disappear".  Despite targetting the apparently correct database for my handler as per the above thread, the problem persisted.  To get around this, I started intercepting saves by global command name, which does work well except for one issue - if the user tries to close a drawing without saving, AutoCAD offers them the option, and they click Yes, the code is bypassed. Will be trying the OnCommandWillStart option to see if that fixes it.
Jeff H
« Reply #21 on: March 04, 2013, 06:00:59 PM »
If you read link posted by trembe Tony mentions problems adding handler multiple times and take a look at your DocumentedCreated and DocumentedActivated handlers.
Using 2013 with AutoSave and no problems.
Fires for each save and still fires after AutoSave has saved for multiple documents.
Code - C#: [Select]
  1. using System;
  2. using Autodesk.AutoCAD.Runtime;
  3. using Autodesk.AutoCAD.ApplicationServices;
  4. using Autodesk.AutoCAD.DatabaseServices;
  5. using Autodesk.AutoCAD.Geometry;
  6. using Autodesk.AutoCAD.EditorInput;
  7. using System.IO;
  8.
  9.
  10. // This line is not mandatory, but improves loading performances
  11. [assembly: ExtensionApplication(typeof(AutoCAD_CSharp_plug_in1.MyPlugin))]
  12.
  13.
  14. namespace AutoCAD_CSharp_plug_in1
  15. {
  16.
  17.
  18.     // This class is instantiated by AutoCAD once and kept alive for the
  19.     // duration of the session. If you don't do any one time initialization
  20.     // then you should remove this class.
  21.     public class MyPlugin : IExtensionApplication
  22.     {
  23.
  24.
  25.         void IExtensionApplication.Initialize()
  26.         {
  27.             DocumentCollection docs = Application.DocumentManager;
  28.             foreach (Document doc in docs)
  29.             {
  30.                 doc.Database.BeginSave += new DatabaseIOEventHandler(Database_BeginSave);
  31.             }
  32.
  33.
  34.             docs.DocumentCreated += new DocumentCollectionEventHandler(docs_DocumentCreated); ;
  35.         }
  36.
  37.
  38.         void docs_DocumentCreated(object sender, DocumentCollectionEventArgs e)
  39.         {
  40.
  41.             e.Document.Database.BeginSave += new DatabaseIOEventHandler(Database_BeginSave);
  42.         }
  43.
  44.
  45.         void Database_BeginSave(object sender, DatabaseIOEventArgs e)
  46.         {
  47.             if (Path.GetExtension(e.FileName) != ".sv$")
  48.             {
  49.                 Application.ShowAlertDialog(e.FileName);
  50.             }
  51.
  52.         }
  53.
  54.
  55.         void IExtensionApplication.Terminate()
  56.         {
  57.             // Do plug-in application clean up here
  58.         }
  59.
  60.
  61.     }
  62.
  63.
  64. }
trembre
« Reply #22 on: March 04, 2013, 07:36:30 PM »
Thanks Jeff - your code solves the problems I was having - my event only fires once, survives autosaves and works on close-save.  Now to figure out why - when I changed my code as per Tony and n.yuan's input, I wasn't too far off what you've written yet still had that issue...
Jeff H
« Reply #23 on: March 04, 2013, 08:37:00 PM »
I thought the code posted was following Tony and Norman's(n.yuan) advice.
trembre
« Reply #24 on: March 04, 2013, 11:03:52 PM »
It is, hence my confusion!  I'll have to dig out that code from my repository and compare it to yours.  While I got the point Tony and Norman were making at the time, I must have botched something else in the code...
EDIT: After resurrecting that code turns out it does follow the same logic and does work.  :ugly:  Must've mixed up my dlls when I was testing - I'll get my coat.
« Last Edit: March 05, 2013, 07:39:27 PM by trembre »
sybold
« Reply #25 on: March 28, 2013, 08:16:00 AM »
it has been a while, been very busy.
this is great, i now realize what i was doing wrong.
all is working again
