Imports System
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports System.IO
<Assembly: ExtensionApplication(GetType(savehandler_2013.MyPlugin))>
Namespace savehandler_2013
Public Class MyPlugin
Implements IExtensionApplication
Private _DocumentManager As DocumentCollection
Private Shared _Controllers As Dictionary(Of Document, PerDocController)
Public Sub Initialize() Implements IExtensionApplication.Initialize
'#### document controller ####
_DocumentManager = Application.DocumentManager
_Controllers = New Dictionary(Of Document, PerDocController)
For Each document As Document In _DocumentManager
_Controllers.Add(document, New PerDocController(document))
Next
AddHandler _DocumentManager.DocumentActivated, AddressOf DocumentActivated
AddHandler _DocumentManager.DocumentCreated, AddressOf DocumentCreated
AddHandler _DocumentManager.DocumentToBeDestroyed, AddressOf DocumentToBeDestroyed
End Sub
Public Sub Terminate() Implements IExtensionApplication.Terminate
RemoveHandler _DocumentManager.DocumentActivated, AddressOf DocumentActivated
RemoveHandler _DocumentManager.DocumentCreated, AddressOf DocumentCreated
RemoveHandler _DocumentManager.DocumentToBeDestroyed, AddressOf DocumentToBeDestroyed
End Sub
Private Sub DocumentActivated(sender As Object, e As DocumentCollectionEventArgs)
If Not (_Controllers.ContainsKey(e.Document)) Then
_Controllers.Add(e.Document, New PerDocController(e.Document))
e.Document.Editor.WriteMessage(vbCrLf + " - Document Activated! ")
End If
End Sub
Private Sub DocumentToBeDestroyed(sender As Object, e As DocumentCollectionEventArgs)
If (_Controllers.ContainsKey(e.Document)) Then
_Controllers(e.Document).Destroy()
_Controllers.Remove(e.Document)
End If
End Sub
Private Sub DocumentCreated(sender As Object, e As DocumentCollectionEventArgs)
e.Document.Editor.WriteMessage(vbCrLf + " - Document Created! ")
End If
End Sub
End Class
Public Class PerDocController
Private _Document As Document
Public Sub New(ByVal document As Document)
_Document = document
If Not Getblockid("sqldataholder") = ObjectId.Null Then
AddHandler _Document.Database.BeginSave, AddressOf BeginSave
AddHandler _Document.Database.SaveComplete, AddressOf SaveComplete
_Document.Editor.WriteMessage(vbCrLf + " - Savehandler Added! ")
End If
End Sub
Public Sub Destroy()
RemoveHandler _Document.Database.BeginSave, AddressOf BeginSave
RemoveHandler _Document.Database.SaveComplete, AddressOf SaveComplete
End Sub
Function Getblockid(ByVal blockName As String) As ObjectId
Dim RetBlkId As ObjectId = ObjectId.Null
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Try
Using tr As Transaction = db.TransactionManager.StartTransaction
Dim bt As BlockTable = db.BlockTableId.GetObject(OpenMode.ForRead)
Dim btr As BlockTableRecord = bt(blockName).GetObject(OpenMode.ForRead)
Dim brefCount As Integer = 0
For Each objId As ObjectId In btr.GetBlockReferenceIds(True, True)
brefCount = btr.GetBlockReferenceIds(True, True).Count
If brefCount > 1 Then
ed.WriteMessage(vbCrLf & " - mutiple blocks found, check drawing!")
Exit Function
ElseIf brefCount = 0 Then
ed.WriteMessage(vbCrLf & " - Block, " & blockName & " not found on screen")
Exit Function
Else
Dim ent As Entity = objId.GetObject(OpenMode.ForRead)
RetBlkId = ent.ObjectId
End If
Next
End Using
Catch ex As Autodesk.AutoCAD.Runtime.Exception
ed.WriteMessage(vbCrLf & " - Block, " & blockName & " not found")
End Try
Return RetBlkId
End Function
Sub SetAttribute(ByVal blockId As ObjectId, ByVal attTag As String, ByVal attVal As String)
Try
Dim br As BlockReference
Dim ac As AttributeCollection
br = blockId.GetObject(OpenMode.ForWrite)
ac = br.AttributeCollection
Dim ent As ObjectId
Dim ar As AttributeReference
For Each ent In ac
ar = ent.GetObject(OpenMode.ForWrite)
If String.Compare(ar.Tag.ToUpper, attTag.ToUpper, True) = 0 Then
ar.TextString = attVal
End If
Next
tr.Commit()
tr.Dispose()
End Using
ed.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
End Try
End Sub
Private Sub BeginSave(sender As Object, e As DatabaseIOEventArgs)
_Document.Editor.WriteMessage(vbCrLf + " - Begin Save! ")
_Document.Editor.WriteMessage(vbCrLf + " - step 1! ")
Try
SetCustomProperty("sql", "true")
_Document.Editor.WriteMessage(vbCrLf & "Error: {0}" & vbCrLf & "Stack trace: {1}", ex.Message, ex.StackTrace)
End Try
_Document.Editor.WriteMessage(vbCrLf + " - step 2! ")
Try
SetCustomProperty("user", Environ$("USERNAME"))
End Try
_Document.Editor.WriteMessage(vbCrLf + " - step 3! ")
Try
SetCustomProperty
("DATEUPD",
Format(Date.Now,
"dd-MM-yy")) Catch ex As Autodesk.AutoCAD.Runtime.Exception
End Try
_Document.Editor.WriteMessage(vbCrLf + " - step 4! ")
Try
SetAttribute(Getblockid("testblock"), "tag", "value")
End Try
End If
'' send block data to sql db.
'sendtosqldb("sqldataholder")
Dim w As StreamWriter = File.AppendText("c:\temp\savehandlerlog.txt")
logger(_Document.Name, w)
End Sub
Private Sub SaveComplete(sender As Object, e As DatabaseIOEventArgs)
_Document.Editor.WriteMessage(vbCrLf + " - Save Complete! ")
End Sub
Private Sub logger(ByVal logMessage As String, ByVal w As TextWriter)
w.Write(ControlChars.CrLf & "Log Entry : ")
w.WriteLine("{0} {1}", DateTime.Now.ToLongTimeString(), DateTime.Now.ToLongDateString())
w.WriteLine(" :")
w.WriteLine(" :{0}", logMessage)
w.WriteLine("-------------------------------")
' Update the underlying file.
w.Flush()
End Sub
Sub SetCustomProperty(ByVal Name As String, ByVal Value As String)
Dim Builder As DatabaseSummaryInfoBuilder = New DatabaseSummaryInfoBuilder(db.SummaryInfo)
If Builder.CustomPropertyTable.Contains(Name) Then
Builder.CustomPropertyTable.Item(Name) = Value
Else
Builder.CustomPropertyTable.Add(Name, Value)
End If
db.SummaryInfo = Builder.ToDatabaseSummaryInfo
End Sub
End Class
End Namespace
