Author Topic: anyone here use getexcel.lsp?  (Read 3016 times)
andrew_nao
« on: February 25, 2013, 01:34:41 PM »
if so do you have any issues using this?
ive been using it to write info but i just started to use it to get the info and with the function "openexcel.." it physically opens the file.
im just curious if this is an issue with me or if the code does this to everyone.
Matt__W
  • I like my water diluted.
Re: anyone here use getexcel.lsp?
« Reply #1 on: February 25, 2013, 02:18:04 PM »
What does it do?  Are you using it to link an Excel file into AutoCAD?  If so, there's a command for that but the name of the command escapes me at the moment, sooo.... basically I've offered no help here.   :|
Autodesk Expert Elite
andrew_nao
« Reply #2 on: February 25, 2013, 02:46:29 PM »
i figured it out. sometimes a fresh pair of eyes is all it takes...
i was using openexcel instead of getexcel.. all is good
thanks for the reply
Matt__W
« Reply #3 on: February 25, 2013, 03:17:29 PM »
Glad I could be of no help.   :wink:  :kewl:
trogg
