Author Topic: using cond instead of if..  (Read 2437 times)
andrew_nao
« on: February 25, 2013, 10:20:47 AM »
how would i set up the cond function to use like the example instead of multiple if's?
example
(if (= var "a")
  (do my thing)
(if (= var "b")
  (do my thing)
(if (= var "c")
  (do my thing)
or is the cond function only used when setting variable?
like so...
  (SETQ var
(COND
   ((WCMATCH var "A-*") "A")
   ((WCMATCH var "B-*") "B")
   ((WCMATCH var "C-*") "C")
Re: using cond instead of if..
« Reply #1 on: February 25, 2013, 10:30:52 AM »
In general, it would depend upon the behaviour you are looking to achieve, since cond ceases evaluation of subsequent test expressions upon a test expression for a condition returning a non-nil value.
Hence in general, the question of whether cond may be used is equivalent to asking whether your if statements could be written:
  1. (if <test-expression-1>
  2.     <then-expression-1>
  3.     (if <test-expression-2>
  4.         <then-expression-2>
  5.         (if <test-expression-3>
  6.             <then-expression-3>
  7.             ...
  8.         )
  9.     )
  10. )
The above is then equivalent to:
  1.     (   <test-expression-1>
  3.     )
  4.     (   <test-expression-2>
  5.         <then-expression-2>
  6.     )
  7.     (   <test-expression-3>
  8.         <then-expression-3>
  9.     )
  10.     (   ...   )
  11. )
However, this question is obvious for your scenario, since the variable 'var' can only hold one value, so this value must be either "a", "b" or "c". Therefore, the set of consecutive if statements could be written as a nested structure:
  1. (if (= var "a")
  2.     (progn
  3.         (do my thing)
  4.     )
  5.     (if (= var "b")
  6.         (progn
  7.             (do my thing)
  8.         )
  9.         (if (= var "c")
  10.             (progn
  11.                 (do my thing)
  12.             )
  13.         )
  14.     )
  15. )
Which indicates that cond could be used instead:
  1.     (   (= var "a")
  2.         (do my thing)
  3.     )
  4.     (   (= var "b")
  5.         (do my thing)
  6.     )
  7.     (   (= var "c")
  8.         (do my thing)
  9.     )
  10. )
andrew_nao
« Reply #2 on: February 25, 2013, 10:40:18 AM »
excellent explaination Lee, as always.
thanks for the help :)
« Reply #3 on: February 25, 2013, 10:50:42 AM »
andrew_nao
« Reply #4 on: February 25, 2013, 11:50:14 AM »
excellent read.. thanks CAB
« Reply #5 on: February 25, 2013, 12:04:15 PM »
You're welcome Andrew.
@CAB, a thorough explanation - I've referred members to it many a time.  8-)
« Reply #6 on: February 25, 2013, 12:37:52 PM »
Thanks fellas.  8-)
