Author Topic: Block of a bolt, array problem  (Read 11959 times)
AdamS
Re: Block of a bolt, array problem
« Reply #15 on: March 08, 2013, 01:22:43 AM »
Hi CAB,
Did you ever solve your block issue ? I'm happy to try and help if you would like.
Jeff H
« Reply #16 on: March 08, 2013, 02:56:04 AM »
Do you mean something like this?
Has two different ones where it stretches from each side and other stretches from midpoint.
« Reply #17 on: March 08, 2013, 07:37:08 AM »
Thanks.
Here are my latest bolts.
The problem I found is that I wanted to scale them to approximate the size needed. But when I do the LIST of sizes
is modified by ACAD. My intent was to have set lengths 2" through 5" in 1/4" increments & through 10" in 1/2" increments.
I made the list of sizes but when the block is scaled ACAD modified the list too.
Tried your iron and mostly works, although when I moved the block some lines became hidden.
My block, can't find the drawing at the moment, was to allow a stretch in the width direction too for size adjustment.
Stretching of the arcs alluded me.
