Author Topic: Block of a bolt, array problem  (Read 11962 times)
« on: February 23, 2013, 08:43:48 PM »
I've been getting acquainted with dynamic blocks, (yes about time)
The attached block "Bolt No Nut" is one that I am having a problem with (ACAD2006)
The way it is designed works OK. That is when you stretch it the threads array & display properly.
The issue is that the dimension needs to be the bolt length like this picture, but the way I have designed
it the length is from the thread that is arrayed. I'm sure I'm just missing the correct procedure.
Also attached is an example of a metric screw which represents what I am ultimately trying to achieve.
Note that using it a drawing I scale the block to the correct size (close enough to actual size), then stretch to length desired.
nobody
  • .net stuff
Re: Block of a bolt, array problem
« Reply #1 on: February 23, 2013, 10:50:57 PM »
Hey CAB,
I believe what you want is to add a "lookup" action to the length of the block.  Unfortunately I've never had to do it myself so am unable to help ya :/ sorry
« Reply #2 on: February 23, 2013, 11:35:14 PM »
Yes, the lookup will come once I solve the current problem.
Looking at the screw block you see that the length linear parameter encompass the entire screw.
My bolt needs to encompass the entire shaft length.
nobody
  • .net stuff
« Reply #3 on: February 24, 2013, 12:48:05 AM »
Is a pain I see... the length is no problem, but getting the array right is a pain. I'm stuck where you are lol. Hopefully someone will jump in and save the day.
« Last Edit: February 24, 2013, 12:55:12 AM by Alien »
« Reply #4 on: February 24, 2013, 08:52:09 AM »
Thanks for trying.
The Swamp is slow on weekends and I'm in no hurry.
I did find some more video tutorials I'm viewing now.
http://www.dgcad.com/Acad2006-DynamicBlocks.htm
« Reply #5 on: February 24, 2013, 09:44:49 AM »
OK, figured out how it works.
I was able to have two separate linear parameters & stretch & array actions.
The key is to select a stretch area that includes one part of the array - linear parameter.
« Reply #6 on: February 24, 2013, 11:32:16 AM »
Improved block.   8-)
Threads re-sized to allow bolt length to stretch in increments of 1/4"
Min length is 1".
nobody
  • .net stuff
« Reply #7 on: February 24, 2013, 06:27:50 PM »
Improved block.   8-)
Min length is 1".
Okay, so what's the difference between yours and the one I tried that's making the one I tried not work lol. This is driving me nuts!   :lol:
« Last Edit: February 24, 2013, 06:34:34 PM by Alien »
« Reply #8 on: February 24, 2013, 09:40:59 PM »
Look at the picture I posted. The dotted rectangle is the "stretch frame" for the stretch action.
Notice that it grabs one leg of the array "linear property".
I believe that that is the key to making the array action happen when you stretch the bolt.
FYI, I am working on an anchor bolt and some others.
See attached.
« Reply #9 on: February 24, 2013, 09:55:37 PM »
OK, I just tried your block, I had to re-apply the stretch action.
It is critical that you select the linear property of the array and I think the grip too when asked to select objects.
You had the stretch frame correct.
Procedures are quite tricky in the dynamic blocks as I have discovered.
I'm not sure of all the correct procedures yet.  :?
nobody
  • .net stuff
« Reply #10 on: February 25, 2013, 07:45:14 AM »
Think my stuff is bugged... gonna try this again at work. I also reapplied the stretch, selected the linear parameter, and the array grip. I left the grip on.  The stretch moves the array grip, but the threads don't update until I actually select the grip for the array. So lame
nobody
  • .net stuff
« Reply #11 on: February 25, 2013, 07:46:40 AM »
Very cool blocks btw! If I was a nuts and bolts guy I'd definitely "borrow".  Unfortunately I just play with dirt lol (I work in the land development world).
« Reply #12 on: February 25, 2013, 09:17:25 AM »
I touch the edges of land dev.  :-)
When I do crude site plan for the houses I design.
I also do some drawing for an engineer that includes some very limited site work. It's fun exploring outside your own box.  8-)
The bolts are for drawings I am doing for the engineer, very small bridges, metal parts for water treatment plant, etc.
The dynamic blocks will save me some time. I plan on doing a profile view of angle iron with a wipeout next.
The angle Iron block will help a lot, see below. Being able to stretch from both ends.
« Reply #13 on: March 01, 2013, 06:23:59 AM »
This is a perfect example of where one could benefit from using ASD.
« Reply #14 on: March 01, 2013, 08:20:39 AM »
I don't work in this area regularly so I can't justify the cost of more software.  :-)
Plus I like to explore but the Angle Iron Block has got me stumped at the moment.
