Author Topic: F: or C:  (Read 11465 times)
rugaroo
  • The Other CAD Guy
F: or C:
« on: September 30, 2003, 09:40:04 PM »
Can someone please give me a general explination of the difference between what f: and c: does? I notice that the f: only works when I have LDD loaded. Just curious.
Rug
LDD06-09 | C3D 04-19 | Infraworks 360 | VS2012-VS2017
daron
F: or C:
« Reply #1 on: October 01, 2003, 10:24:32 AM »
The way I understand it is you can put any letter before :. But, if anybody has more info on the matter, I'd like to know, too. Thanks.
SMadsen
F: or C:
« Reply #2 on: October 01, 2003, 11:43:22 AM »
What are you guys talking about?  :shock:
daron
F: or C:
« Reply #3 on: October 01, 2003, 11:52:11 AM »
(defun C: or I: or F: or nothing ()...)
I'm thinking that.
Or the way Bell does it:
(defun ax:BuildFilter (filter)
  (mapcar '(lambda (lst typ)
    (vlax-make-variant
      (vlax-safearray-fill
(vlax-make-safearray
  typ
  (cons 0
(1- (length lst))
lst
 (list (mapcar 'car filter) (mapcar 'cdr filter))
 (list vlax-vbInteger vlax-vbVariant)
F: or C:
« Reply #4 on: October 01, 2003, 11:55:44 AM »
Dude, there is no "F" prefix. The "C" prefix is of-course the one that makes the function an autocad command.
Alot of people put prefixes on thier functions. (Mark and i do it when we work on a program together so we can tell who made a function.) for reference type of thing. But i know of NO "f" prefix.
daron
F: or C:
« Reply #5 on: October 01, 2003, 12:02:24 PM »
Okay, so it's just a way to put a signature on a function. It does nothing for the function like c: does, huh?
F: or C:
« Reply #6 on: October 01, 2003, 12:13:28 PM »
Nope. Sorry.
rugaroo
  • The Other CAD Guy
F: or C:
« Reply #7 on: October 01, 2003, 12:51:22 PM »
Ok...well if anyone here is using LDD try this: (f:adcmds 22)
F: or C:
« Reply #8 on: October 01, 2003, 01:07:47 PM »
Yes but.......
Command: (f:adcmds 22)
There are no alignments defined.
Command: adcmds
Unknown command "ADCMDS"
the f:adcmds is no different that say mst-adcmds, it's just the name of the function.
if you look in <LDD installed folder>\Land you will see many .lsp files, at least 76 of those use F: in their function name.
rugaroo
  • The Other CAD Guy
F: or C:
« Reply #9 on: October 01, 2003, 01:31:03 PM »
I was just getting confused as to why this would be used rather that just the c:. And for some reason, mst-adcmds does not work on mine.
daron
F: or C:
« Reply #10 on: October 01, 2003, 01:54:49 PM »
That's because you probably don't have that MarkSThomas-function.
rugaroo
  • The Other CAD Guy
F: or C:
« Reply #11 on: October 01, 2003, 02:06:32 PM »
Oooops..he he....Time to wake up and smell the concrete!
