Author Topic: Getting first attribute value in a block  (Read 4164 times)
nobody
  • .net stuff
« on: February 22, 2013, 05:03:50 AM »
I see lots of examples online to get ALL the values in a block, but is there a way to get just the first one without using a "foreach" and "break"? Seems sufficient enough but feels brutal to the process... what happens if "break" causes an actual break (crash at same time or something)?
Guess I'm used to lisp, where one can specify the attribute value one wants to collect.
Just a noobs curiosity.
Thanks!
« Last Edit: February 22, 2013, 06:03:28 AM by Alien »
huiz
  • Certified Prof C3D
Re: Getting first attribute value in a block
« Reply #1 on: February 22, 2013, 06:03:10 AM »
You still have to check if there are attributes, so you just can't get the first attribute as GetMyAtrtibute(0).
nobody
  • .net stuff
« Reply #2 on: February 22, 2013, 06:07:24 AM »
Didn't think about it that way. Thank you!
huiz
« Reply #3 on: February 22, 2013, 07:12:57 AM »
Don't worry about performance, if I extract attributes and insertion point location from 5000 blocks and put them in a ListView, it takes less then half a second.
nobody
  • .net stuff
« Reply #4 on: February 22, 2013, 07:23:57 AM »
MexicanCustard
« Reply #5 on: February 22, 2013, 07:54:14 AM »
IF you are using Tony T's Runtime Extension Methods you can simplify getting one attribute.
var db = Application.DocumentManager.MdiActiveDocument.Database;
    var bt = (BlockTable)db.BlockTableId.GetObject(OpenMode.ForRead);
    var btr = (BlockTableRecord)bt["MYBLOCK"].GetObject(OpenMode.ForRead);
    var att = btr.Cast<ObjectId>()
        .Where(id=> id.IsTypeOf<AttributeDefinition>())  <-- Need Tony T's extension method here
        .Select(id => (AttibuteDefinition)id.GetObject(OpenMode.ForRead))
        .Where(att => att.Tag == "MY_TAG")
        .FirstOrDefault();
    if (att != null)
        //Do what you want with the single attribute
If you know that its a specific block and it always has specific attributes
    var att = btr.GetObjects<AttributeDefinition>().FirstOrDefault(a=>a.Tag == "MY_TAG);
    if (att != null)
« Last Edit: February 22, 2013, 08:23:21 AM by MexicanCustard »
bargool
« Reply #6 on: February 22, 2013, 01:15:52 PM »
Could you post link to this methods, please?
nobody
  • .net stuff
« Reply #7 on: February 22, 2013, 01:20:53 PM »
2nd this
MexicanCustard
bargool
« Reply #9 on: February 22, 2013, 01:44:34 PM »
Oh ye! Thank you!
nobody
  • .net stuff
gile
  • Marseille, France
« Reply #11 on: February 22, 2013, 04:07:05 PM »
Hi Alien,
If you're looking for the first attribute of a block reference (BlockReference) instead of a block definition (BlockTableRecord), you can use some LINQ extension methods:
  • Cast<> to convert the AttributeCollection into an IEnumerable<ObjectId> usable with Linq methods.
  • Any<> to check if the collection isn't empty.
  • First<> to get the iENumerable first item.
Here's a little snippet (assuming br is a BlockReference)
Code - C#: [Select]
  1.                 IEnumerable<ObjectId> atts = br.AttributeCollection.Cast<ObjectId>();
  2.                 if (atts.Any())
  3.                 {
  4.                     AttributeReference attRef =
  5.                         (AttributeReference)atts.First().GetObject(OpenMode.ForRead);
  6.                     // ...
  7.                 }
  8.                 else
  9.                 {
  10.                     // ...
  11.                 }
nobody
  • .net stuff
« Reply #12 on: February 22, 2013, 06:38:27 PM »
Fantastic!!! Thank you!
TheMaster
« Reply #13 on: February 22, 2013, 08:26:04 PM »
With WinForms or WPF ?
huiz
« Reply #14 on: February 23, 2013, 04:43:24 AM »
Winforms. Actually it wasn't a listview but a datagrid. I've timed the operation from filtering blocks, extracting attributes and locations of 5250 entities, and in 489 milliseconds the data was placed in the datagrid.
