Author Topic: help text to list  (Read 1831 times)
TopoWAR
help text to list
« on: February 20, 2013, 03:11:14 PM »
hello, a help please, I have the following string:
(read "(b (91.1849 87.7505 0.0))")but I need to return the value b = b and b = B not,
return value like this:
'(b (91.1849 87.7505 0.0))
took 2 hours trying everything and I returned the b and B,  :oops: help me thank you
« Last Edit: February 20, 2013, 03:31:31 PM by TopoWAR »
Thanks for help
Re: help text to list
« Reply #1 on: February 20, 2013, 03:57:48 PM »
The B is a variable NAME and B is the same as b in the eyes of LISP.
TopoWAR
« Reply #2 on: February 20, 2013, 04:04:29 PM »
CAB ,
see, I do the following, I convert a list to a text string, as shown in b is a text
(setq est (vl-princ-to-string (list "b" '(100. 100. 0.0))))
the problem that when I use
(read est)I returned b uppercase:
'(B (100.0 100.0 0.0))I need to return the same value as before: lower case b
I need is retrieve back the string "b"
I hope I explained, thanks
« Last Edit: February 20, 2013, 04:18:56 PM by TopoWAR »
Thanks for help
« Reply #3 on: February 20, 2013, 04:15:26 PM »
I see what you are doing.
You need to separate the individual items and recreate the list. Read will convert to uppercase, so you need to do something like this:
(setq val (substr est 2 1))
As you see, the "b" in the string is extracted to a new variable
Without understanding the larger use, it is difficult to provide guidance.
What are you trying to do?
TopoWAR
« Reply #4 on: February 20, 2013, 04:23:15 PM »
it is a solution.
so I would stay to the end.
thanks :laugh:
(setq est (vl-princ-to-string (list "abc" '(100. 100. 0.0))))
(setq val (substr est 2 (1- (vl-string-search " " est))))
Thanks for help
« Reply #5 on: February 20, 2013, 05:07:15 PM »
Glad to be of assistance
« Reply #6 on: February 20, 2013, 06:11:02 PM »
Alternatively, you could use vl-prin1-to-string to preserve the string data type:
_$ (read (vl-prin1-to-string '("b" (100.0 100.0 0.0))))
TopoWAR
« Reply #7 on: February 20, 2013, 06:32:02 PM »
Lee Mac , excellent :lol:
as simple as changing
vl-princ-to-stringby
vl-string-to-prin1
thanks for sharing.
« Last Edit: February 20, 2013, 06:39:30 PM by TopoWAR »
Thanks for help
