Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
ENTMAKE BLOCK Troubles
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: ENTMAKE BLOCK Troubles (Read 1778 times)
snownut2
Swamp Rat
Bricscad 22 Ultimate
WWW
on:
February 19, 2013, 06:28:25 PM »
In trying to assemble a block from any number of LWPOLYLINES I seem to be missing something. My code is below, as the LWPOLYLINES are being created with an ENTMAKE I am generating a list of entity names the LWentL variable is the list, all appears fine with the list.
Sample of the generated list; (<Entity name: 7eb4dde8> <Entity name: 7eb4ddd8> <Entity name: 7eb4ddc8>)
Actual list is much longer....
Code - Auto/Visual Lisp:
[Select]
ENTMAKE
APPLY
FUNCTION
APPEND
CONS
List
0
"BLOCK"
CONS
2
strcat
tabname blk
70
0
10
0.0
0.0
0.0
MAPCAR
FUNCTION
LIST
MAPCAR
FUNCTION
LAMBDA
a
CONS
2
a
LWentL
ENTMAKE
0
"ENDBLK"
Logged
Global Moderator
Seagull
Re: ENTMAKE BLOCK Troubles
Reply #1 on:
February 19, 2013, 07:35:11 PM »
Hint
(APPLY 'APPEND
Logged
Seagull
London, England
WWW
Reply #2 on:
February 19, 2013, 07:45:13 PM »
You will need to first entmake the
BLOCK
entity, then entmake the
LWPOLYLINE
s, and finally the
ENDBLK
entity; else the
LWPOLYLINE
entities will be created in the drawing (modelspace/paperspace) rather than within the block definition.
For example:
[Select]
entmake
list
0
"BLOCK"
cons
2
strcat
tabname blk
70
0
10
0.0
0.0
0.0
entmake
0
"LWPOLYLINE"
;; Anything created here
entmake
0
"LWPOLYLINE"
;; will be part of the
entmake
0
"LWPOLYLINE"
;; block definition
entmake
0
"ENDBLK"
Logged
Lee Mac Programming
Twitter
Exchange App Store
snownut2
Swamp Rat
WWW
Reply #3 on:
February 19, 2013, 09:42:47 PM »
Thanks Lee, that did the trick. I was not sure how that would work since I am calling 1/2 dozen sub-functions between starting the block and ending it.
Speed is very good also.
Bruce
Logged
Seagull
London, England
WWW
Reply #4 on:
February 20, 2013, 05:50:08 AM »
You're welcome Bruce
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
