Author Topic: The Lisp asks every time for subroutine  (Read 2767 times)
HasanCAD
« on: February 19, 2013, 05:23:48 AM »
When run this lisp
there is error message
Command: gmf
; error: no function definition: LM:COPYBLOCK
(defun c:GMF ( / BLK DWG E INSPNT N OSN OSOLD SEL SS ) (vl-load-com)
;SUB
(defun *error* (m) ;  Author: Lee Mac,
  (defun insblk (/) ; HasanCAD
(defun algn ( / CMN CMO DXFDATA ENTITY OLD-DXF PNT1 PNT2 SEL)  (vl-load-com) ; HasanCAD
  (defun round (number by)
  (defun LM:ObjectDBXDocument ( / acVer) ;  Author: Lee Mac,
  (defun LM:Itemp ( coll item) ;  Author: Lee Mac,
    (defun LM:CopyBlock ( block filename / acapp acdoc acblk acdocs dbxDoc item ) ;  Author: Lee Mac,
  (defun LM:ObjectDBXDocument ( / acVer ) ;  Author: Lee Mac,
  (defun LM:Popup ( title msg flags / wsh res ) ;  Author: Lee Mac,
(princ "\n:: GMF.lsp | Version 1.0 | Type GMF to invoke the lisp ::")
roy_043
  • BricsCAD 18
Re: The Lisp asks every time for subroutine
« Reply #1 on: February 19, 2013, 05:44:59 AM »
This could be related to the order of the main function. The nested functions should come before the rest of the code. See the examples below. Alternatively you can 'un-nest' the nested functions. If you are nesting functions, declaring their names as local variables makes more sense.
  1. (defun c:Test_Order_Wrong ( / MyPrincFunction)
  2.   (MyPrincFunction "test")
  3.
  4.   ; Nested function
  5.   (defun MyPrincFunction (str)
  6.     (princ str)
  7.   )
  8.
  9.   (princ)
  10. )
  11.
  12. (defun c:Test_Order_OK ( / MyPrincFunction)
  13.
  14.   ; Nested function
  15.   (defun MyPrincFunction (str)
  16.     (princ str)
  17.   )
  18.
  19.   (MyPrincFunction "test")
  20.   (princ)
  21. )
kraz
« Reply #2 on: February 19, 2013, 06:26:20 AM »
Don't you have the function LM:COPYBLOCK
you must load the fuction..and then run your code...
HasanCAD
« Reply #3 on: February 19, 2013, 07:29:26 AM »
Working
Is it better to include the subroutine in main routine
  ; Nested function
    (princ str)
or make it separate
  ; Nested function
    (princ str)
roy_043
  • BricsCAD 18
« Reply #4 on: February 19, 2013, 11:19:14 AM »
What is best depends on the situation.
If a sub-routine is used by only one function I will typically nest the sub-routine (and declare it as a local variable). In all other cases I do not nest sub-routines.
For testing it is easier not to have nested sub-routines. Testing a nested sub-routine separately is harder.
HasanCAD
« Reply #5 on: February 20, 2013, 01:27:14 AM »
Good tip
