Author Topic: Replacing block with VB.Net ObjectARX  (Read 2557 times)
cannorth
« on: February 12, 2013, 05:44:19 PM »
Hello,
  I have some code that inserts blocks into a drawing.  I then need to delete the blocks and then reinsert them again.  The reason I need to reinsert them is because they have dynamic block height and width properties that need to be changed.  If I use a transaction the first time and commit the changes, how can I delete the old blocks and reinsert them in the drawing?
Thanks,
cannorth
TheMaster
Re: Replacing block with VB.Net ObjectARX
« Reply #1 on: February 12, 2013, 11:23:44 PM »
Hello,
Thanks,
cannorth
Have you tried changing the height and width properties on the existing insertions ?
Replacing Dynamic block insertions is not as simple as regular blocks, because they are insertions of anonymous blocks that are generated on the fly when you modify anything in an insertion that triggers a visual change.
cannorth
« Reply #2 on: February 13, 2013, 10:03:52 AM »
Yes, I tried changing the height and width dynamic properties of the block, and it doesn't change.
cannorth
Jeff H
« Reply #3 on: February 13, 2013, 10:10:29 AM »
I am almost certain I have changed dynamic properties it they updated just fine. Will try to find code, but maybe an example block or example would help.
TheMaster
« Reply #4 on: February 13, 2013, 03:21:26 PM »
cannorth
Did you call BlockReference.ResetBlock() after making the changes ?
cannorth
« Reply #5 on: February 14, 2013, 11:15:46 AM »
No I didn't, but when I do blockReference.ResetBlock, nothing changes.
cannorth
Gasty
« Reply #6 on: February 14, 2013, 11:39:58 AM »
Please upload the block along with the code, so others can inspect/test it and avoid a guessing game.
Gaston Nunez
cannorth
« Reply #7 on: February 14, 2013, 01:32:38 PM »
I've created a new topic called move or moving entities.  The new code I'm using is there.
Thanks,
cannorth
