Author Topic: Block Editing With Password Protection  (Read 11726 times)
theluck19
  • ABC (ADDICTED to BOOZE & CAD.)
« on: February 11, 2013, 06:35:45 AM »
Is it possible to this do to this via programming? I am having a tough time with grids being exploded frequently. :pissed:
Win 10 Pro 64+AutoCAD 2019
Rob...
Re: Block Editing With Password Protection
« Reply #1 on: February 11, 2013, 07:18:00 AM »
Not sure about that but how about XREFs in a write protected folder?
CAD Tech
Krushert
  • FREE BEER Tomorrow!!
« Reply #2 on: February 11, 2013, 10:33:30 AM »
IN the block file, call the block editor command for the current drawing and in the properties palette set the "Allow Exploding" value to "no".
This in affects locks the file with a padlock.  Anybody with some brains can get around it but typical those people should with brains know the value of not exploding a grid.    YMMV
I no longer CAD or Model, I just hang out here for camaraderie
danallen
« Reply #3 on: February 11, 2013, 12:42:48 PM »
Could you code a reactor to monitor for explode events of certain named blocks and either pop up an alert, or write to a network log file that you can monitor separately? They'll wonder at your omniscientness...
Krushert
« Reply #4 on: February 11, 2013, 01:27:50 PM »
Actually there is a phone home code around TheSwamp somewhere.
Drafter X
« Reply #5 on: February 11, 2013, 01:35:46 PM »
oooh, I need that
CadJockey Militia Commander
theluck19
« Reply #6 on: February 11, 2013, 11:11:23 PM »
I need that too, desperately. I tried changing the value of explode to no in Block Editor, but some guys here are too wise to that.
dgorsman
« Reply #7 on: February 12, 2013, 10:29:58 AM »
If exploding things is not standard procedure, time for management to earn their money and play the bad-guy, and start yelling at people.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Drafter X
« Reply #8 on: February 12, 2013, 10:59:26 AM »
I meant the phone home code, LOL
found some of my custom blocks out 'in the wild' so to speak. Don't mind so much really, but part of my contract is that clients cannot share my stuff without written permission.  I know its going to happen, but still nice to know how far they wander, lol.
theluck19
« Reply #9 on: February 12, 2013, 10:59:13 PM »
I
I did yell!!, but this is a big job and the guy is pretty new to CAD. The problem is his mistake caused a lot of rework to others. Now i've asked guys never to explode Blocks or Dims and if the really need to.. have a word with me.  :realmad:
Crank
« Reply #10 on: February 19, 2013, 01:08:59 PM »
I can't find the original posting, but I believe the attached code was created by Luis.
It isn't perfect, but wil get you started.
Vault Professional 2018     +     AEC Collection
Matt__W
  • I like my water diluted.
« Reply #11 on: February 19, 2013, 01:43:05 PM »
i've asked guys never to explode... Dims and if the really need to..
There is absolutely no acceptable answer to the questions "Why are you exploding the dimensions?" or "Why do you have to explode the dimensions?"
Autodesk Expert Elite
Rob...
« Reply #12 on: February 19, 2013, 01:45:53 PM »
Ooo, ooo, I got one.
"I didn't do it."
CAD Tech
dgorsman
« Reply #13 on: February 19, 2013, 02:07:53 PM »
"The client says to."
try {GreatPower;}
   finally
      {MasterBasics;}
theluck19
« Reply #14 on: February 20, 2013, 01:31:47 AM »
Keep.lsp is a step in the right direction for me. Some tweeking and I can add it to the startup suite. Will let u know how thins go from here on!! :-) :-) Thanks!!
