Author Topic: Is there a better way to lock all viewports?  (Read 2213 times)
bchapman
« on: February 08, 2013, 10:50:13 PM »
Just finished this. Seems convoluted... is there a better solution?
namespace BCLOCKVP
    public class BCCLOCKVIEWPORTS
        [CommandMethod("BCC:LOCKVP")]
        static public void BCCLOCKVP()
            Document curDoc = Application.DocumentManager.MdiActiveDocument;
            Database docdb = curDoc.Database;
            ObjectIdCollection BCCVIEWPORTS = docdb.GetViewports(true);
            LayoutManager lm = LayoutManager.Current;
            Editor ed = curDoc.Editor;
            using (Transaction ts = curDoc.TransactionManager.StartTransaction())
                DBDictionary layoutDict = docdb.LayoutDictionaryId.GetObject(OpenMode.ForRead) as DBDictionary;
                foreach (DBDictionaryEntry de in layoutDict)
                    Layout layout = de.Value.GetObject(OpenMode.ForRead) as Layout;
                    string layoutName = layout.LayoutName;
                    lm.CurrentLayout = layoutName;
                    ObjectIdCollection vpIdCol = layout.GetViewports();
                    foreach (ObjectId vpId in vpIdCol)
                        Viewport vp = vpId.GetObject(OpenMode.ForWrite) as Viewport;
                        vp.Locked = true;
                        ed.WriteMessage("VP {0} is Locked", layoutName);
                ts.Commit();
bchapman
Re: Is there a better way to lock all viewports?
« Reply #1 on: February 09, 2013, 08:50:39 PM »
None?  Apparently I'm pro after a week :p bahahahahahah
namespace BCLOCKVP
                        vp.Locked = true;
                ts.Commit();
Jeff H
« Reply #2 on: February 09, 2013, 09:12:26 PM »
Any reason for not just enumerating through ObjectIds from
Also the argument passed for GetViewports
Input flag indicating whether to return paperspace viewports associated with layouts
In your situation you would want it to be false, and using this method you might to initialize uninitialized viewports.
« Last Edit: February 09, 2013, 09:15:53 PM by Jeff H »
bchapman
« Reply #3 on: February 09, 2013, 09:23:08 PM »
Thanks! No reason...  I didn't know how to siphon through all the layouts to get the viewports... so I cut that piece from an unrelated program out there... don't remember what it was.
is this what you were recommending?
// locks viewports
namespace BCLOCKVP
                foreach (ObjectId de in BCCVIEWPORTS)
                        Viewport vp = de.GetObject(OpenMode.ForWrite) as Viewport;
                        vp.Locked = true;
               ts.Commit();
bchapman
« Reply #4 on: February 09, 2013, 09:41:44 PM »
By the way this forum needs a + system to give kudos to peeps like you.
