Author Topic: < Challenge > Integers into words / Ordinal Numbers into words  (Read 23528 times)
PKENEWELL
Re: < Challenge > Integers into words / Ordinal Numbers into words
« Reply #45 on: December 17, 2018, 09:44:29 AM »
Hello!
And how to make words-> int?
From "twenty one thousand five hundred thirty seven" in 21537.
For example.
Already created in this topic: http://www.theswamp.org/index.php?topic=43830.msg491651#msg491651
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Dilan
« Reply #46 on: December 17, 2018, 05:43:05 PM »
Hello!
For example.
Thank you very much for the two answers.
« Reply #47 on: December 17, 2018, 05:45:42 PM »
Here are a pair of complementary functions:
Integer to Words
  1. (defun LM:int->words ( n / f1 f2 )
  2.     (defun f1 ( n )
  3.         (if (< n 20)
  4.             (nth (fix n) '("" "one" "two" "three" "four" "five" "six" "seven" "eight" "nine" "ten" "eleven" "twelve" "thirteen" "fourteen" "fifteen" "sixteen" "seventeen" "eighteen" "nineteen"))
  5.             (strcat (nth (- (fix (/ n 10)) 2) '("twenty" "thirty" "forty" "fifty" "sixty" "seventy" "eighty" "ninety")) " " (f1 (rem n 10)))
  6.         )
  7.     )
  8.     (defun f2 ( n l )
  9.         (cond
  10.             (   (null l) (f1 n))
  11.             (   (< n (caar l)) (f2 n (cdr l)))
  12.             (   (vl-string-right-trim " " (strcat (f2 (fix (/ n (caar l))) (cdr l)) " " (cadar l) " " (f2 (rem n (caar l)) (cdr l)))))
  13.         )
  14.     )
  15.     (if (zerop n)
  16.         "zero"
  17.         (vl-string-right-trim " "
  18.             (f2 n
  19.                '(
  20.                     (1e18 "quintillion")
  21.                     (1e15 "quadrillion")
  22.                     (1e12 "trillion")
  23.                     (1e09 "billion")
  24.                     (1e06 "million")
  25.                     (1e03 "thousand")
  26.                     (1e02 "hundred")
  27.                 )
  28.             )
  29.         )
  30.     )
  31. )
Words to Integer
  1. (defun LM:words->int ( s / f1 f2 )
  2.     (defun f1 ( s l / p )
  3.         (cond
  4.             (   (null l)
  5.                 (cond
  6.                     (   (vl-position (vl-string-trim " " s)
  7.                            '("" "one" "two" "three" "four" "five" "six" "seven" "eight" "nine" "ten" "eleven" "twelve" "thirteen" "fourteen" "fifteen" "sixteen" "seventeen" "eighteen" "nineteen")
  8.                         )
  9.                     )
  10.                     (   0   )
  11.                 )
  12.             )
  13.             (   (not (setq p (vl-string-search (car l) s))) (f1 s (cdr l)))
  14.             (   (+ (* 10 (- 10 (length l))) (f1 (substr s (+ 2 p (strlen (car l)))) (cdr l))))
  15.         )
  16.     )
  17.     (defun f2 ( s l / p )
  18.         (cond
  19.             (   (null l) (f1 s '("twenty" "thirty" "forty" "fifty" "sixty" "seventy" "eighty" "ninety")))
  20.             (   (not (setq p (vl-string-search (caar l) s))) (f2 s (cdr l)))
  21.             (   (+ (* (f2 (substr s 1 p) (cdr l)) (cadar l)) (f2 (substr s (+ 2 p (strlen (caar l)))) (cdr l))))
  22.         )
  23.     )
  24.     (if (= "zero" (strcase s t))
  25.         0
  26.         (f2 (strcase s t)
  27.            '(
  28.                 ("quintillion" 1e18)
  29.                 ("quadrillion" 1e15)
  30.                 ("trillion"    1e12)
  31.                 ("billion"     1e09)
  32.                 ("million"     1e06)
  33.                 ("thousand"    1e03)
  34.                 ("hundred"     1e02)
  35.             )
  36.         )
  37.     )
  38. )
Examples:
  1. _$ (rtos (LM:words->int (LM:int->words 3)) 2 0)
  2. "3"
  3. _$ (rtos (LM:words->int (LM:int->words 31)) 2 0)
  4. "31"
  5. _$ (rtos (LM:words->int (LM:int->words 314)) 2 0)
  6. "314"
  7. _$ (rtos (LM:words->int (LM:int->words 3141)) 2 0)
  8. "3141"
  9. _$ (rtos (LM:words->int (LM:int->words 31415)) 2 0)
  10. "31415"
  11. _$ (rtos (LM:words->int (LM:int->words 314159)) 2 0)
  12. "314159"
  13. _$ (rtos (LM:words->int (LM:int->words 3141592)) 2 0)
  14. "3141592"
  15. _$ (rtos (LM:words->int (LM:int->words 31415926)) 2 0)
  16. "31415926"
  17. _$ (rtos (LM:words->int (LM:int->words 314159265)) 2 0)
  18. "314159265"
  19. _$ (rtos (LM:words->int (LM:int->words 3141592653)) 2 0)
  20. "3141592653"
  21. _$ (rtos (LM:words->int (LM:int->words 31415926535)) 2 0)
  22. "31415926535"
  23. _$ (rtos (LM:words->int (LM:int->words 314159265358)) 2 0)
  24. "314159265358"
  25. _$ (LM:int->words 314159265358)
  26. "three hundred fourteen billion one hundred fifty nine million two hundred sixty five thousand three hundred fifty eight"
  27. _$ (rtos (LM:words->int "three hundred fourteen billion one hundred fifty nine million two hundred sixty five thousand three hundred fifty eight") 2 0)
  28. "314159265358"
« Last Edit: December 17, 2018, 06:03:54 PM by Lee Mac »
