Author Topic: lisp error in ACAD2004  (Read 5751 times)
danny
« Reply #15 on: March 15, 2005, 12:12:03 AM »
thanks Kerry, thanks CAB... I'll read up on the debbuging program.
« Reply #16 on: March 15, 2005, 03:03:07 AM »
danny,
Charles is correct of course .. as you would have determined once you isolated the line the error was on, then made the variable  SLST temporarily global then tried to use the line (command ".PEDIT" "L" "J" SLST "" "") at the command line. Command line changes are a real pain to catch sometimes. You might want to have a look at the Pedit 'Multiple'
option too.
« Reply #17 on: March 15, 2005, 03:07:05 AM »
Quote from: danny
< .. > I'll read up on the debbuging program.
That will help a lot for future issues.
Just a tip : Animation can be fun, but setting a breakpoint and stepping is a little more productive. :
The watch window can be a big help too ...
and ..
As Stig indicated earlier, setting a breakpoint gives you access to the INSPECT tools so that you can check variable values without the need to add a lot of prompt or princ statements in a suspected buggy block of code.
