Here it is the C# solution and the dll in case anyone wants to run the test for this command.
Note, it does a filter to ignore some layers.
Command name: SLP
Command: slp
Elapsed=68msecs. 79msecs // here it is returning also the timing using the system variable millisecs- value on the right.
[CommandMethod("SLP")]
public void cmd_shortestLongestPlinesOnLayer()
var e = AcadApp.DocumentManager.MdiActiveDocument.Editor;
using (var tr = e.Document.Database.TransactionManager.StartTransaction())
var layerTable = tr.GetObject(e.Document.Database.LayerTableId, OpenMode.ForRead) as LayerTable;
var sw = Stopwatch.StartNew();
var st = (int)AcadApp.GetSystemVariable("millisecs");
foreach (var layerId in layerTable)
var layer = tr.GetObject(layerId, OpenMode.ForRead) as LayerTableRecord;
if (layer.Name.Equals("Defpoints") || layer.IsFrozen || layer.IsOff || layer.Name.Contains("|"))
continue;
var pairs = new Dictionary<double, Polyline3d>();
PromptSelectionResult psr;
if (SelectionOfPLines(e, layer.Name, out psr)) continue;
foreach (var id in psr.Value.GetObjectIds())
var pline = tr.GetObject(id, OpenMode.ForWrite, false) as Polyline3d;
if (pline.Layer != layer.Name) continue;
pairs.Add(pline.Length, pline);
pline.Erase(true);
psr.Value.Dispose();
if (pairs.Count <= 0) continue;
var dict = pairs.Keys;
var maxLine = dict.Max();
var minLine = dict.Min();
var ll = pairs[maxLine];
var sl = pairs[minLine];
ll.Erase(false);
sl.Erase(false);
pairs.Clear();
sw.Stop();
var et = (int)AcadApp.GetSystemVariable("millisecs");
e.WriteMessage("\nElapsed={0}msecs. {1}msecs \n", sw.ElapsedMilliseconds, (et - st).ToString());
tr.Commit();
private static bool SelectionOfPLines(Editor e, string layerName, out PromptSelectionResult psr)
TypedValue[] tv = { new TypedValue((int)DxfCode.Start, "POLYLINE"), new TypedValue((int)DxfCode.LayerName, layerName) };
var filter = new SelectionFilter(tv);
psr = e.SelectAll(filter);
return psr.Status != PromptStatus.OK;
