Author Topic: ( Challenge ) Shortest & Longest Pline  (Read 13596 times)
« on: February 04, 2013, 08:52:49 AM »
The challenge is to find the shortest and longest Pline by layer. Erase all others. The attached .dwg contains 1624 3D polylines on 4 layers. Bonus points to the fastest code. :)
Thanks again to Lee Mac for the code to create the .dwg  WARNING: do not try to create 2000 polylines and then erase them! You will be waiting on your computer for some time. LOL
Good luck!
Marc'Antonio Alessi
  • Marco
Re: ( Challenge ) Shortest & Longest Pline
« Reply #1 on: February 04, 2013, 09:32:11 AM »
Surely this type of approach (as previous) has its greatest speed in DWG with large number of objects:
  1. (defun C:ShortLongestPL ( / SelSet Countr EntSht EntLng LenVal MaxLen MinLen)
  2.  (if (setq SelSet (ssget "_X" '((0 . "POLYLINE"))))
  3.    (progn
  4.      (if (= 1 (logand 1 (getvar "UNDOCTL"))) (command "_.UNDO" "_C" "_N"))
  5.      (setvar "HIGHLIGHT" 0)
  6.      (setq
  7.        Countr 0
  8.        EntSht (ssname SelSet 0)
  9.        EntLng EntSht
  10.        MaxLen (vla-get-length (vlax-ename->vla-object EntSht))
  11.        MinLen  MaxLen
  12.      )
  13.      (repeat (sslength SelSet)
  14.        (setq
  15.          EntNam (ssname SelSet Countr)
  16.          LenVal (vla-get-length (vlax-ename->vla-object EntNam))
  17.          Countr (1+ Countr)
  18.        )
  19.        (cond
  20.          ( (> LenVal MaxLen) (setq MaxLen LenVal  EntLng EntNam) )
  21.          ( (< LenVal MinLen) (setq MinLen LenVal  EntSht EntNam) )
  22.        )
  23.      )
  24.      (command "_.ERASE" SelSet "_R" (ssadd EntSht (ssadd EntLng)) "")
  25. ;      (princ (strcat "\n" (itoa Countr) " erased entity(es). Use Oops to restore. "))
  26.    )
  27.    (alert "No lines to erase.")
  28.  )
  29. )
  30. ; By Layer version
  31. (defun C:ShortLongestPLByLyr ( / TblDat SelSet SelSt2 Countr EntSht EntLng
  32.                                  EntDat EntNam LenVal MaxLen MinLen AllSet)
  33.   (if (= 1 (logand 1 (getvar "UNDOCTL"))) (command "_.UNDO" "_C" "_N"))
  34.   (setvar "HIGHLIGHT" 0)
  35.   (setq SelSt2 (ssadd))
  36.   (while (setq TblDat (tblnext "LAYER" (null TblDat)))
  37.     (if (setq
  38.           SelSet (ssget "_X" (list '(0 . "POLYLINE") (cons 8 (cdr (assoc 2 TblDat)))))
  39.         )
  40.       (progn
  41.         (setq
  42.           Countr 0
  43.           EntSht (ssname SelSet 0)
  44.           EntLng EntSht
  45.           MaxLen (vla-get-length (vlax-ename->vla-object EntSht))
  46.           MinLen  MaxLen
  47.         )
  48.         (repeat (sslength SelSet)
  49.           (setq
  50.             EntNam (ssname SelSet Countr)
  51.             LenVal (vla-get-length (vlax-ename->vla-object EntNam))
  52.             Countr (1+ Countr)
  53.           )
  54.           (cond
  55.             ( (> LenVal MaxLen) (setq MaxLen LenVal  EntLng EntNam) )
  56.             ( (< LenVal MinLen) (setq MinLen LenVal  EntSht EntNam) )
  57.           )
  58.         )
  59.         (setq
  60.           SelSt2 (ssadd EntSht SelSt2)  SelSt2 (ssadd EntLng SelSt2)
  61.           AllSet (cons SelSet AllSet)
  62.         )
  63.       )
  64.     )
  65.   )
  66.   (command "_.ERASE") (foreach ForElm AllSet (command ForElm))
  67.   (command  "_R" SelSt2 "")
  68. )
irneb
« Reply #2 on: February 04, 2013, 11:20:51 PM »
Didn't you have the same question just recently? If using the vlax-curve-* functions it would work the same (or at least very similar) to the method for finding the longest & shortest lines.
Marc'Antonio Alessi
  • Marco
« Reply #3 on: February 05, 2013, 04:21:24 AM »
My apologies for my english, is it a question for me? If so please can you give me an example?
Marco
Tharwat
  • Hypersensitive
« Reply #4 on: February 05, 2013, 05:44:40 AM »
Marco
I think irneb indicating to the following thread .  :-D
http://www.theswamp.org/index.php?topic=43714.0
Marc'Antonio Alessi
  • Marco
« Reply #5 on: February 05, 2013, 07:33:46 AM »
Maybe the question it is not for me.
« Reply #6 on: February 05, 2013, 07:38:21 AM »
The only difference in this challenge is the .dwg contains 3D Plines.
Try doing it without vlax-*.
irneb
« Reply #7 on: February 05, 2013, 07:45:00 AM »
Fine I assumed it's something like that. Thus you'd want this to be a case of adding polyline segment lengths together.
Now I can just imagine the next challenge  ;) : 2d Polylines with curved sgments.
irneb
« Reply #8 on: February 05, 2013, 12:55:42 PM »
OK, to pre-empt all this  :lmao: :
  1. (defun curveLength  (start end bulge)
  2.   (cond ((or (not bulge) (zerop bulge)) (distance start end))
  3.         (t (* 4.0 (atan (abs bulge)) (/ (* (distance start end) (1+ (* bulge bulge))) 4 (abs bulge))))))
  4.
  5. (defun getEntityLayer+Length  (eName / eDXF 70DXF eType points bulges)
  6.   (setq eDXF (entget eName '("*")))
  7.   (list
  8.     (cdr (assoc 8 eDXF))
  9.     (cond
  10.       ((wcmatch (setq eType (cdr (assoc 0 eDXF))) "LINE") ;Line
  11.        (distance (cdr (assoc 10 eDXF)) (cdr (assoc 11 eDXF))))
  12.       ((wcmatch eType "POLYLINE") ;Heavy Polyline
  13.        (setq 70DXF (cdr (assoc 70 eDXF)))
  14.        ;; Get vector info
  15.        (while (and (setq eName (entnext eName))
  16.                    (setq eDXF (entget eName))
  17.                    (wcmatch (cdr (assoc 0 eDXF)) "VERTEX"))
  18.          (setq points (cons (cdr (assoc 10 eDXF)) points)
  19.                bulges (cons (cdr (assoc 42 eDXF)) bulges)))
  20.        (setq points (reverse points)
  21.              bulges (reverse bulges))
  22.        (cond
  23.          ((> (logand 70DXF 0) ;If 3d Polyline
  24.           (cond ((> (logand 70DXF 1) 0) ;If closed
  25.                  (apply '+ (mapcar 'distance (cons (last points) points) points)))
  26.                 ;; Else not closed
  27.                 (t (apply '+ (mapcar 'distance points (cdr points))))))
  28.          ;; Else 2d Polyline - possibly bulges
  29.          (t
  30.           (cond ((> (logand 70DXF 1) 0) ;If closed
  31.                  (apply '+ (mapcar 'curveLength (cons (last points) points) points (cons (last bulges) bulges))))
  32.                 ;; Else not closed
  33.                 (t (apply '+ (mapcar 'curveLength points (cdr points) bulges)))))))
  34.       ((wcmatch eType "LWPOLYLINE")
  35.        (setq 70DXF (cdr (assoc 70 eDXF)))
  36.        (foreach item  (member (assoc 90 eDXF) eDXF)
  37.          (cond ((= (car item) 10) (setq points (cons (cdr item) points)))
  38.                ((= (car item) 42) (setq bulges (cons (cdr item) bulges)))))
  39.        (setq points (reverse points)
  40.              bulges (reverse bulges))
  41.        (cond ((> (logand 70DXF 1) 0) ;If closed
  42.               (apply '+ (mapcar 'curveLength (cons (last points) points) points (cons (last bulges) bulges))))
  43.              ;; Else not closed
  44.              (t (apply '+ (mapcar 'curveLength points (cdr points) bulges))))))))
  45.
  46. (defun c:RemAllButLongest&Shortest  (/ ss long short n en)
  47.   (setq long  '(nil nil -1.0)
  48.         short '(nil nil 1.7976931348623158e308))
  49.   (if (setq ss (ssget "_X" '((0 . "LINE,POLYLINE,LWPOLYLINE"))))
  50.     (progn (repeat (setq n (sslength ss))
  51.              (setq en (ssname ss (setq n (1- n)))
  52.                    en (cons en (getEntityLayer+Length en)))
  53.              (if (> (caddr en) (caddr long))
  54.                (setq long en))
  55.              (if (< (caddr en) (caddr short))
  56.                (setq short en))
  57.              (entdel (car en)))
  58.            (entdel (car long))
  59.            (entdel (car short))
  60.            (princ (strcat "\nLongest :\tLayer="
  61.                           (cadr long)
  62.                           ";\tLength ="
  63.                           (rtos (caddr long))
  64.                           "\nShortest:\tLayer="
  65.                           (cadr short)
  66.                           ";\tLength ="
  67.                           (rtos (caddr short))
  68.                           "\n"))))
  69.   (princ))
  70.
And the test:
_$ (DoTest '((c:RemAllButLongest&Shortest)))
(C:REMALLBUTLONGEST&SHORTEST)
Longest :    Layer=RED;    Length =71652.0653
Shortest:    Layer=RED;    Length =243.2759
Program running time: 1030 msecs.
« Last Edit: February 05, 2013, 12:59:30 PM by irneb »
irneb
« Reply #9 on: February 05, 2013, 01:13:10 PM »
or using the vlax-curve-* idea (despite your comment to "not" use it):
  1. (defun c:RemAllButLongest&Shortest1  (/ ss long short n en lay len)
  2.   (setq long  '(nil nil -1.0)
  3.         short '(nil nil 1.7976931348623158e308))
  4.   (if (setq ss (ssget "_X" '((0 . "LINE,POLYLINE,LWPOLYLINE"))))
  5.     (progn (repeat (setq n (sslength ss))
  6.              (setq en (ssname ss (setq n (1- n)))
  7.                    lay (cdr (assoc 8 (entget en)))
  8.                    len (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
  9.              (if (> len (caddr long))
  10.                (setq long (list en lay len)))
  11.              (if (< len (caddr short))
  12.                (setq short (list en lay len)))
  13.              (entdel en))
  14.            (entdel (car long))
  15.            (entdel (car short))
  16.            (princ (strcat "\nLongest :\tLayer="
  17.                           (cadr long)
  18.                           ";\tLength ="
  19.                           (rtos (caddr long))
  20.                           "\nShortest:\tLayer="
  21.                           (cadr short)
  22.                           ";\tLength ="
  23.                           (rtos (caddr short))
  24.                           "\n"))))
  25.   (princ))
And the test:
_$ (DoTest '((c:RemAllButLongest&Shortest) (c:RemAllButLongest&Shortest1)))
Program running time: 1045 msecs.
(C:REMALLBUTLONGEST&SHORTEST1)
Program running time: 93 msecs.
BTW, I've used Lee's time-it function in a combined version, so I am assured of "equal" allowance for each version:
  1. (defun time-it  (expr / et st)
  2.   ;; by: Lee Mac
  3.   (setq st (getvar 'millisecs))
  4.   (eval expr)
  5.   (setq et (getvar 'millisecs))
  6.   (princ (strcat "Program running time: " (itoa (- et st)) " msecs."))
  7.   (princ))
  8.
  9. (defun DoTest  (exprlist /)
  10.   (foreach expr exprlist (command "_.undo" "_Back" "_Yes") (print expr) (time-it expr))
  11.   (princ))
Not much in the order of which version to perform first:
_$ (DoTest '((c:RemAllButLongest&Shortest1) (c:RemAllButLongest&Shortest)))
Program running time: 78 msecs.
Program running time: 1077 msecs.
irneb
« Reply #10 on: February 05, 2013, 02:01:53 PM »
Just to compare apples with apples:
  1. (defun c:RemAllButLongest&ShortestByLayer  (/ ss long short n en lay len)
  2.   (while (setq lay (tblnext "LAYER" (not lay)))
  3.     (setq long  '(nil nil -1.0)
  4.           short '(nil nil 1.7976931348623158e308))
  5.     (if (setq ss (ssget "_X" (list '(0 . "LINE,POLYLINE,LWPOLYLINE") (cons 8 (cdr (assoc 2 lay))))))
  6.       (progn (repeat (setq n (sslength ss))
  7.                (setq en  (ssname ss (setq n (1- n)))
  13.                (entdel en))
  15.              (entdel (car short)))))
  16.   (princ))
And the test for all 5:
_$ (DoTest '((c:RemAllButLongest&Shortest1) (c:RemAllButLongest&Shortest) (C:ShortLongestPL) (C:ShortLongestPLByLyr) (c:RemAllButLongest&ShortestByLayer)))
Program running time: 63 msecs.
Program running time: 967 msecs.
(C:SHORTLONGESTPL) Program running time: 125 msecs.
(C:SHORTLONGESTPLBYLYR) Program running time: 141 msecs.
(C:REMALLBUTLONGEST&SHORTESTBYLAYER) Program running time: 47 msecs.
irneb
« Reply #11 on: February 05, 2013, 02:08:47 PM »
Oh! Noticed a slight hiccup: If there's only one entity on the layer, then it will get erased. So here's the fix (with a minor optimization):
  3.     (setq long  '(nil -1.0)
  4.           short '(nil 1.7976931348623158e308))
  5.     (if (and (setq ss (ssget "_X" (list '(0 . "LINE,POLYLINE,LWPOLYLINE") (cons 8 (cdr (assoc 2 lay))))))
  6.              (> (setq n (sslength ss)) 1))
  7.       (progn (repeat n
  8.                (setq en  (ssname ss (setq n (1- n)))
  9.                      len (vlax-curve-getDistAtParam en (vlax-curve-getEndParam en)))
  10.                (if (> len (cadr long))
  11.                  (setq long (list en len)))
  12.                (if (< len (cadr short))
  13.                  (setq short (list en len)))
  14.                (entdel en))
  15.              (entdel (car long))
  16.              (entdel (car short)))))
  17.   (princ))
Test:
Program running time: 983 msecs.
Marc'Antonio Alessi
  • Marco
« Reply #12 on: February 05, 2013, 02:42:00 PM »
I think I know why this version is faster, is there anyone who knows?
Marc'Antonio Alessi
  • Marco
« Reply #13 on: February 05, 2013, 04:17:08 PM »
This is the answer:
  1. ;AutoCAD 2010
  2. ;(time-it '(c:RemAllButLongest&Shortest1)) ;Program running time: 421 msecs.
  3. ;(time-it '(c:ALE_ShortLongestPL))       ;Program running time: 265 msecs
  4.
  5. (defun C:ALE_ShortLongestPL ( / SelSet Countr EntSht LenVal MinLen InfLst)
  6.  (if (setq SelSet (ssget "_X" '((0 . "POLYLINE"))))
  7.    (progn
  8.      (setq
  9.        Countr 0
  10.        EntSht (ssname SelSet 0)
  11.        MinLen (vla-get-length (vlax-ename->vla-object EntSht))
  12.        InfLst (list EntSht MinLen EntSht MinLen)
  13.      )
  14.      (repeat (sslength SelSet)
  15.        (setq
  16.          EntNam (ssname SelSet Countr)
  17.          LenVal (vla-get-length (vlax-ename->vla-object EntNam))
  18.          Countr (1+ Countr)
  19.        )
  20.        (cond
  21.          ( (> LenVal (cadddr InfLst))
  22.            (setq InfLst (list (car InfLst) (cadr InfLst) EntNam LenVal))
  23.          )
  24.          ( (< LenVal (cadr   InfLst))
  25.            (setq InfLst (list EntNam LenVal (caddr InfLst) (cadddr InfLst)))
  26.          )
  27.        )
  28.      )
  29.      (command "_.ERASE" SelSet "_R" (ssadd (car InfLst) (ssadd (caddr InfLst))) "")
  30.    )
  31.  )
  32. )
« Reply #14 on: February 05, 2013, 04:46:15 PM »
This one fares pretty well:
Program running time: 188 msecs.
  1. (defun c:testfoo (/ e el l l2 lyr n o ss)
  2.   (if (setq ss (ssget "_x" '((0 . "POLYLINE"))))
  3.     (progn (setq n -1)
  4.            (while (setq e (ssname ss (setq n (1+ n))))
  5.              (setq o (vlax-ename->vla-object e))
  6.              (setq l (cons (list (vla-get-layer o) (vla-get-length o) e) l))
  7.              (entdel e)
  8.            )
  9.            (setq l (vl-sort l (function (lambda (a b) (< (car a) (car b))))))
  10.            (while (setq lyr (caar l))
  11.              (while (eq (caar l) lyr) (setq l2 (cons (car l) l2)) (setq l (cdr l)))
  12.              (setq l2 (vl-sort l2 (function (lambda (a b) (< (cadr a) (cadr b))))))
  13.              (entdel (last (car l2)))
  14.              (entdel (last (last l2)))
  15.              (setq l2 nil)
  16.            )
  17.     )
  18.   )
  19. )
Nice Irneb  8-)
« Last Edit: February 05, 2013, 04:52:03 PM by ronjonp »
