That would simply result in a new string of the form:
Basically if you princ that string it would result in something like this:
123 "789"
You might be getting confused due to the escaped " - they do make the appearance of the code a bit garbled. Remember that the \ character is used as an indication that the next character has special meaning. E.g. in your code the \ is used in 2 scenarios:
- \" - means there's a double quote inside the sting. If it wasn't escaped with the back-slash, then there would be no way to add a " into a string.
- \n - means add a new line () character to the string.
