Author Topic: Custom Palette Blank  (Read 2717 times)
flowerrobot
« on: February 04, 2013, 12:43:10 AM »
Hey guys
For some reason, When I create a custom Palette it comes out blank.
I thought maybe it was my code. So I created a test app, however same result
        <CommandMethod("ad")> _
        Public Sub MyCommand() ' This method can have any name
            Dim PalSet As PaletteSet = Nothing
            PalSet = New PaletteSet("CustPalette")
            Dim test As New CustPalette
            PalSet.Add("CustPalette", test)
            PalSet.Visible = True
My form just has a label but is not shown in AutoCAD. nor add items added to it.
I would really appreciate your help
Panzee
  • Mosquito
Re: Custom Palette Blank
« Reply #1 on: February 04, 2013, 08:39:20 AM »
Try this:
            Dim PalSet As PaletteSet = New PaletteSet("CustPalette")
            Dim test As CustPalette = New CustPalette
Its from http://forums.autodesk.com/autodesk/attachments/autodesk/152/26712/1/CP205-2_Mike_Tuersley.pdf
Creating a Docking Palette for AutoCADŽ with VB.NET
MexicanCustard
« Reply #2 on: February 04, 2013, 08:43:11 AM »
I wrap my palettes in an ElementHost object
Your example in C# sorry Im not a VB guy
[CommandMethod("ad")]
        public void MyCommand()
            var PalSet = new PaletteSet("CustPalette");
            var test = new CustPalette();
            var host = new ElementHost { AutoSize = true, Dock = DockStyle.Fill, Child = test };
            PalSet.Add("CustPalette", host);
            PalSet.Visible = True;
TheMaster
« Reply #3 on: February 04, 2013, 11:24:33 AM »
Hey guys
A Palette requires a Control. You don't show what 'CustPalette' is, and you referred to a 'form', which I don't think can be added to a Palette.
BlackBox
« Reply #4 on: February 04, 2013, 06:58:52 PM »
flowerrobot
« Reply #5 on: February 04, 2013, 10:19:35 PM »
Thanks guys TT is the winner.  I was using the Form not a container. such a simple mistake and so easily overlooked.
MexicanCustard why do you encapsulate your container? I couldn't get the library to "ElementHost" so I gave up trying that.
Thanks alot guys
flowerrobot
« Reply #6 on: February 04, 2013, 11:51:32 PM »
I just noticed there is no "close" for containers
On the term of "container" class, What are they really? Are forms derived from these?
MexicanCustard
« Reply #7 on: February 06, 2013, 08:06:52 AM »
I use WPF to create my palettes and the ElementHost handles filling the palette. So I can make my form any size I want and the element host always controls filling the palette so things look good.
ElementHost is in System.Windows.Forms.Integration
TheMaster
« Reply #8 on: February 06, 2013, 08:30:59 AM »
If you mean ContainerControl, this is not a designable control. You should create a UserControl (WinForms) to use as the control on your Palette.
