Author Topic: VB.Net  (Read 1610 times)
RAJA
  • Mosquito
VB.Net
« on: February 04, 2013, 12:38:03 AM »
Hello all
I am create some set of lines and poly-lines and then i select on particular location using "Select Fence" command in vb.net. But Prompt selection Result showing  Error -5001.
How i can select objects in code running.
Thank You for all
Gasty
Re: VB.Net
« Reply #1 on: February 04, 2013, 08:03:33 AM »
That possible mean that nothing was selected/found, make sure that all the objects to be selected are visible in the screen before the select operation. If that is not the reason, please post the code and intended use case for that code.
Gaston Nunez
