using System;
using System.Linq;
using System.Text;
using System.ComponentModel;
/// Quick/dirty - strip xdata from entities created by
/// the OFFSET command, in this example uses the XDATA
/// appname "MYXDATA"
namespace Autodesk.AutoCAD.ApplicationServices.MyExtensions
public class MyApplication : IExtensionApplication
public void Initialize()
OffsetCommandObserver.Inititlize();
public void Terminate()
public abstract class XDataManagerOverrule : ObjectOverrule
string appname = null;
TypedValue[] empty = null;
Document doc = null;
Database db = null;
public XDataManagerOverrule( Document doc, string appname )
this.appname = appname;
this.doc = doc;
this.db = doc.Database;
empty
= new TypedValue
[] { new TypedValue
( 1001, appname
) }; AddOverrule
( RXClass
.GetClass( typeof( Entity
this,
true ); SetXDataFilter( appname );
public override void Close( DBObject dbObject )
if( dbObject.IsNewObject && dbObject.IsWriteEnabled && dbObject.Database == db )
using( ResultBuffer rb = dbObject.GetXDataForApplication( appname ) )
if( rb != null )
UpdateXData( dbObject, rb );
base.Close( dbObject );
protected virtual void UpdateXData( DBObject dbObject, ResultBuffer rb )
bool disposed = false;
protected override void Dispose( bool disposing )
if( disposing && ! disposed )
RemoveOverrule
( RXClass
this ); disposed = true;
base.Dispose( disposing );
/// <summary>
/// Avoids full-time handling of end-command events;
/// </summary>
public abstract class CommandObserver : IDisposable
bool handled = false;
public CommandObserver( Document doc )
if( doc == null )
throw new ArgumentNullException
( "doc" ); this.doc = doc;
this.doc.CommandWillStart += commandWillStart;
public enum State
Starting = 0,
Ended = 1,
Cancelled = 2,
Failed = 3
public Document Document
get
return this.doc;
void commandWillStart( object sender, CommandEventArgs e )
if( OnCommandStarting( e.GlobalCommandName ) )
AddEndHandlers();
void AddEndHandlers()
if( !this.handled )
doc.CommandEnded += doc_CommandEnded;
doc.CommandFailed += doc_CommandFailed;
doc.CommandCancelled += doc_CommandCancelled;
this.handled = true;
void RemoveEndHandlers()
if( this.handled )
doc.CommandEnded -= doc_CommandEnded;
doc.CommandFailed -= doc_CommandFailed;
doc.CommandCancelled -= doc_CommandCancelled;
this.handled = false;
/// Overrides should return true to be notified
/// when a command ends (otherwise, there is no
/// end-of-command notification).
protected virtual bool OnCommandStarting( string name )
return false;
protected virtual void OnCommandEnded( string name, State state )
void doc_CommandCancelled( object sender, CommandEventArgs e )
RemoveEndHandlers();
OnCommandEnded( e.GlobalCommandName, State.Cancelled );
void doc_CommandFailed( object sender, CommandEventArgs e )
OnCommandEnded( e.GlobalCommandName, State.Failed );
void doc_CommandEnded( object sender, CommandEventArgs e )
OnCommandEnded( e.GlobalCommandName, State.Ended );
protected virtual void Dispose( bool disposing )
if( !disposed )
doc.CommandWillStart -= this.commandWillStart;
disposed = true;
public void Dispose()
Dispose( true );
public class OffsetCommandObserver : CommandObserver
OffsetXDataOverrule overrule = null;
static DocData<OffsetCommandObserver> manager = null;
public static void Inititlize()
// Dummy method to invoke static c'tor
static OffsetCommandObserver()
manager
= new DocData
>( doc
=> new OffsetCommandObserver
( doc
public OffsetCommandObserver( Document doc )
: base( doc )
protected override bool OnCommandStarting( string name )
if( name.Equals( "OFFSET", StringComparison.OrdinalIgnoreCase ) )
overrule
= new OffsetXDataOverrule
( this.Document,
"MYXDATA" ); return true;
return false;
protected override void OnCommandEnded( string name, State state )
if( overrule != null )
overrule.Dispose();
overrule = null;
class OffsetXDataOverrule : XDataManagerOverrule
public OffsetXDataOverrule( Document doc, string appname )
: base( doc, appname )
empty
= new TypedValue
[] { new TypedValue
( 1001, appname
protected override void UpdateXData( DBObject dbObject, ResultBuffer rb )
using( ResultBuffer buffer
= new ResultBuffer
( empty
dbObject.XData = buffer;
public class DocData<T>
static Type key
= typeof( T
); Func<Document, T> factory = null;
public DocData( Func<Document, T> factory )
this.factory = factory;
DocumentCollection docs = Application.DocumentManager;
foreach( Document doc in docs )
Add( doc );
docs.DocumentCreated += documentCreated;
docs.DocumentToBeDestroyed += documentToBeDestroyed;
void documentToBeDestroyed( object sender, DocumentCollectionEventArgs e )
if( e.Document.UserData.ContainsKey( key ) )
IDisposable disposable = e.Document.UserData[key] as IDisposable;
if( disposable != null )
disposable.Dispose();
void documentCreated( object sender, DocumentCollectionEventArgs e )
Add( e.Document );
private void Add( Document document )
document.UserData[key] = factory( document );
