Author Topic: Blank text remover..  (Read 2473 times)
Andrea
« on: March 14, 2005, 10:41:56 AM »
Hi all..
I'm looking for a routine to remove any blank TEXT and MTEXT in a drawing..
any suggestions ?
 :wink:
Keep smile...
  • Custom Title
« Reply #1 on: March 14, 2005, 11:00:01 AM »
Something along these lines perhaps.
(setq ss (ssget "x" '((0 . "TEXT")(1 . " "))))
t-bear
« Reply #2 on: March 14, 2005, 12:09:52 PM »
Andrea....
I believe there are a number of these here.  Do a search for blank text and/or null text......that should find them.
VerticalMojo
« Reply #3 on: March 14, 2005, 12:17:26 PM »
T-bear...
I tried to do a search and couldn’t find any..... Maybe a different keyword? :?
hudster
« Reply #4 on: March 14, 2005, 12:28:19 PM »
try this
; Delete Null Objects
;; DelNul.lsp
;; Deletes nul lines of Text, Mtext & Blocks.
;; Modified by JL Thomas 12/02/97
(Defun C:DelNul ( / TXT BLK NB NAMES)
  (if(setq TXT (ssget "X" '((-4 . "<and")(-4 . "<or")
                           (0 . "MTEXT")(0 . "TEXT")
                           (-4 . "or>")(-4 . "<or")
                           (1 . "")(1 . " ")(1 . "  ")(1 . "   ")
                           (1 . "{}")(1 . "{ }")(1 . "{  }")(1 . "{   }")
                           (1 . "{}\P")(1 . "{ }\P")(1 . "{  }\P")(1 . "{   }\P")
                           (-4 . "or>")(-4 . "and>"))))
    (command"_erase"TXT"")
    (princ(strcat"\n  "(itoa(sslength TXT))" nul text strings deleted. "))
  (princ"\n  No nul text strings found. "))
  (setq BLK(tblnext"BLOCK"T)NAMES nil)
  (while BLK
    (if(=(cdr(assoc 0(entget(cdr(assoc -2 BLK)))))"ENDBLK")
      (if(setq NB(ssget "X" (list(assoc 2 BLK))))
      (command"_erase"NB"")
    (setq NAMES(cons(cdr(assoc 2 BLK))NAMES))
  (setq BLK(tblnext"BLOCK"))
  (if NAMES
    (progn(textscr)
    (princ"\n  Nul blocks found and need purging: ")
    (foreach X NAMES(princ"\n    ")(princ X))
  (princ"\n  No nul blocks found. ")
(c:DelNul)
MikePerry
« Reply #5 on: March 14, 2005, 12:52:48 PM »
Quote from: VerticalMojo
Hi
Can someone post a copy of delnul.lsp
Have a good one, Mike
VerticalMojo
« Reply #6 on: March 14, 2005, 01:00:02 PM »
Mike your the search master  8)
Andrea
« Reply #7 on: March 14, 2005, 01:04:01 PM »
Hey !!  this work perfectly..
thanks all. 8)
Keep smile...
MikePerry
« Reply #8 on: March 14, 2005, 01:04:08 PM »
Hi "VerticalMojo"
Thanks :oops: <- your kind words have embarrassed me.
I used -
Empty AND Text
as my search criteria.
Cheers, Mike
VerticalMojo
« Reply #9 on: March 14, 2005, 02:49:32 PM »
Mike,
More like  :oops: myself. I should have thought of those key words!
<--- As Homer Simpson would say...... DOH!
