Hey Irneb, I dug into the swamp forums for a while as well as other forums to locate a dcl / lisp that would be similar to this one.
I have a few minor (or not so minor) requests that I would like your help in accomplishing in regards to this dcl / lisp.
Can we add a row under the "Drawings:" column that would be a preview of the block images that are selected in the middle column?
And then for the "okay" button , currently it is set to (princ "Do some stuff if OK is pressed") so, was wondering if we could maybe have the okay button when an attribute is selected from the list of attributes on the furthest right column of the blocks to simply edit that attribute? That would be fairly handy, an alternative way to edit some of these blocks, via this lisp / dcl to tag valves, etc....there are some uses we could derive from something similar to this with these edits, if they would at all be possible to accomplish.
Thanks!
