Author Topic: XOPEN file in Read-Only  (Read 1512 times)
RolandOrzabal
  • "memories fade but the scars still linger"
« on: January 24, 2013, 11:51:02 PM »
Hi swampers...
i often work in a group and there's always an instance where in i need to open other's drawing using XOPEN but i need it to be read-only as to avoid editing / saving the drawing which is not mine and that the owner of that drawing can still open his drawing and edit it if he wants...
 Is there a way that i can use XOPEN and that the file being opened  will be on read-only mode?
irneb
Re: XOPEN file in Read-Only
« Reply #1 on: January 25, 2013, 12:43:01 AM »
I don't think the XOpen command has a ReadOnly option.
Does your code already "know" the xref's entity/name/path? If not there are various ways to get it.
Once you have the path to the xref you could use the ActiveX Documents Collection's Open method. Note it has a readonly parameter.
BlackBox
« Reply #2 on: January 25, 2013, 08:51:33 AM »
Here's an old example.
Randall Culp
« Reply #3 on: January 10, 2017, 08:10:26 PM »
"BUMP"
Anyone have anything that will trip XOPEN to read-only??
Or failing that a reactor of some kind that can redefine XOPEN to copy the selected XREF to a local junk directory and open it there??
Randy Culp
(AKA CADaver)
