Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Entmake a Wipeout in rotated WCS ?
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Entmake a Wipeout in rotated WCS ? (Read 10663 times)
Global Moderator
Seagull
Re: Entmake a Wipeout in rotated WCS ?
Reply #15 on:
February 07, 2013, 12:06:31 PM »
Thought I would share the lisp. Both versions.
This is the Wipeout version.
Code - Auto/Visual Lisp:
[Select]
;; This is a specialised Railing Routine
;; CAB - Jan. 3,2010 to present
;; This version uses Wipeouts
;; Creates an elevation view of 2X Pressure Treated Lumber Hand Rail System
;; Pickets do not touch the deck below
;; Rails are made of 2x4 lumber
;; Rail Cap is made of 2x6 lumber
;; Pickets are made of 2x2 lumber
;; Note: actual lumber sizes are -.5"
defun
c:Railing
a ang b c clr count deflayer dis gap ht m p1 p2 pll rail1 rail2 spc
step tmp whole wid y1 y2 y3 y4 y5
defun
MkWipeout
lst lay
c m p
setq
lst
cons
last
lst
lst
p
apply
mapcar
cons
min
lst
m
apply
max
mapcar
apply
mapcar
cons
max
lst
p
c
mapcar
p
list
m
2.0
m
2.0
entmakex
append
list
000 .
"WIPEOUT"
100
"AcDbEntity"
100
"AcDbWipeout"
cons
8
lay
cons
10
trans
p
1
0
cons
11
trans
list
m
0.0
1
0
cons
12
trans
list
0.0
m
1
0
280
1
071 .
2
mapcar
function
lambda
x
cons
14
mapcar
lambda
a b c
a b
c
x c
list
m
m
lst
defun
up
p a d
polar
p
a
pi
2
d
;; width of pattern 7.5 center of one ballaster to the center of next
;; width of ballaster is 1.5
;; Radius of circle is 3.0
setq
defLayer
"zDtl Light 5"
; picket layer
rail1
"zDtl Medium 5"
rail2
"zDtl Medium 4"
wid
1.5
; picket width
ht
37.0
; picket height
spc
3.5
; space between pickets (max < 4.0")
clr
1.625
; picket clearance from deck
y1
3.5
; height of rail lines
y2
7.0
; y1-y2 are botton rail
y3
37.0
; y3-y4 are top rail
y4
40.5
; y4-y5 are rail cap
y5
42.0
if
and
setq
p1
getpoint
\n
Pick lower left."
setq
p2
getpoint
\n
Pick lower right."
progn
command
"._undo"
"_begin"
if
car
p2
car
p1
setq
tmp p1 p1 p2 p2 tmp
; make left to right
setq
step
wid spc
count
distance
p1 p2
step
whole
1-
fix
count
dis
wid
wid spc
whole
gap
distance
p1 p2
dis
2
ang
angle
p1 p2
pll
polar
polar
p1 ang gap
ang
pi
2
clr
; LowerLeft of 1st picket
;; draw rails from bottom up, numbers are the relative Y position
MkWipeout
list
up p1 ang y4
up p2 ang y4
up p2 ang y3
up p1 ang y3
defLayer
MkWipeout
list
up p1 ang y5
up p2 ang y5
up p2 ang y4
up p1 ang y4
rail1
; top of railing
MkWipeout
list
up p1 ang y1
up p2 ang y1
up p2 ang y2
up p1 ang y2
rail2
; bottom
;; Draw pickets
repeat
1+
whole
MkWipeout
list
pll
polar
pll
ang
pi
2
ht
polar
polar
pll
ang
pi
2
ht
ang wid
polar
pll ang wid
defLayer
setq
pll
polar
pll ang step
command
"._undo"
"_end"
princ
Logged
Global Moderator
Seagull
Reply #16 on:
February 07, 2013, 12:10:03 PM »
This is the Hatch version.
Note that it uses a routine by Lee to correct the draw order of the pline border
The routine can be found here:
http://lee-mac.com/draworderfunctions.html
[Select]
;; This version uses Plines & Hatches, previous version used Wipeouts
defun
c:Railing
ang clr count deflayer dis gap ht lst norm obj p1 p2 pll spc step tmp
whole wid y1 y2 y3 y4 y5 rail1 rail2 hLayer
vl-load-com
defun
mkhatch
spc obj lst lay
hatch spc
vl
catch
all
apply
lambda
setq
hatch
vla-AddHatch
spc acHatchPatternTypePredefined
"SOLID"
:vlax-true
vlax-invoke
hatch 'AppendOuterLoop
list
obj
vla-evaluate
hatch
vla-put-layer
hatch lay
LM:SwapOrder
vla-get-activedocument
vlax-get-acad-object
hatch obj
;; http://lee-mac.com/draworderfunctions.html
;; by CAB 03/22/2009 - modified too close pline
;; Expects pts to be a list of 2D or 3D points
;; Returns new pline object
defun
makePline
spc pts lay
norm elv pline
setq
norm
trans
0
0
1
1
0
T
elv
caddr
trans
car
pts
1
norm
setq
pline
vlax-invoke
Spc 'addLightWeightPolyline
apply
append
mapcar
function
lambda
pt
setq
pt
trans
pt
1
norm
list
car
pt
cadr
pt
pts
vla-put-Elevation
pline elv
vla-put-Normal
pline
vlax-3d-point
norm
vla-put-Closed
pline
:vlax-true
vla-put-Layer
Pline lay
pline
defun
up
p a d
polar
p
a
pi
2
d
;; width of pattern 7.5 center of one picket to the center of next.
;; width of picket is 1.5
setq
defLayer
"zDtl Light 5"
; picket layer
rail1
"zDtl Medium 5"
rail2
"zDtl Medium 4"
hLayer
"WipeOut"
wid
1.5
; picket width
ht
37.0
; picket height
spc
3.5
clr
1.625
y1
3.5
y2
7.0
y3
37.0
y4
40.5
y5
42.0
if
and
setq
p1
getpoint
\n
Pick lower left."
setq
p2
getpoint
\n
Pick lower right."
progn
command
"._undo"
"_begin"
if
car
p2
car
p1
setq
tmp p1 p1 p2 p2 tmp
; make p1-p2 left to right
setq
step
wid spc
count
distance
p1 p2
step
whole
1-
fix
count
dis
wid
wid spc
whole
gap
distance
p1 p2
dis
2
ang
angle
p1 p2
pll
polar
polar
p1 ang gap
ang
pi
2
clr
setq
Spc
if
1
getvar
"CVPORT"
vla-get-PaperSpace
vla-get-ModelSpace
setq
lst
list
up p1 ang y4
up p2 ang y4
up p2 ang y3
up p1 ang y3
setq
obj
makePline spc lst defLayer
mkhatch spc obj lst hLayer
setq
lst
list
up p1 ang y5
up p2 ang y5
up p2 ang y4
up p1 ang y4
setq
obj
makePline spc lst rail1
setq
lst
list
up p1 ang y1
up p2 ang y1
up p2 ang y2
up p1 ang y2
setq
obj
makePline spc lst rail2
;; Draw pickets
repeat
1+
whole
setq
lst
list
pll
polar
pll
ang
pi
2
ht
polar
polar
pll
ang
pi
2
ht
ang wid
polar
pll ang wid
setq
obj
setq
pll
polar
pll ang step
; end repeat
command
"._undo"
"_end"
command
"._regen"
princ
Logged
VovKa
Water Moccasin
Ukraine
Reply #17 on:
February 07, 2013, 01:08:26 PM »
i would add that hatches must be of (255 255 255) RGB color
Logged
Global Moderator
Seagull
Reply #18 on:
February 07, 2013, 01:32:36 PM »
Thanks, my LAYER "Wipeout" is set to color 255
Logged
VovKa
Water Moccasin
Ukraine
Reply #19 on:
February 07, 2013, 02:39:48 PM »
Quote from: CAB on February 07, 2013, 01:32:36 PM
have you plotted it already? indexed color 255 will become RGB (250 250 250) when printed out and may turn into gray.
so i suggest using true color (255 255 255) which is 'pure' white
Logged
Global Moderator
Seagull
Reply #20 on:
February 07, 2013, 02:59:55 PM »
You're quite right and I should have mentioned I use STB method with a
style
called Wipeout also.
The style color is 254 254 254 which is what controls my plotting.
Sorry for the confusion.
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
