Author Topic: Count Items in a list  (Read 8328 times)
Re: Count Items in a list
« Reply #30 on: December 05, 2016, 08:57:28 AM »
Of all the weird ways to say "that flavor has already been written" that was the most recent I've read.
I don't recall seeing Stefan's submission before -- great minds think alike?
Marc'Antonio Alessi
  • Marco
« Reply #31 on: December 05, 2016, 09:18:42 AM »
https://www.theswamp.org/index.php?topic=50539.msg556727#msg556727
« Reply #32 on: December 05, 2016, 09:42:06 AM »
Cool beans, thanks Marc.
Grrr1337
« Reply #33 on: December 05, 2016, 06:06:37 PM »
Nice thread, thanks for bumping it up. Now I've remembered that gotta figure out such counter for an association lists.
(list
'("A" "B" 10)
'("A" "C" 20)
'("B" "C" 10)
'("A" "B" 10)
'("A" "C" 20)
'("A" "B" 10)
(list
'(("A" "B" 10) . 3)
'(("A" "C" 20) . 2)
'(("B" "C" 10) . 1)
(apply ''((a b c)(a b c))
vevo.bg
« Reply #34 on: December 05, 2016, 06:21:13 PM »
It's been done. I'd search for you but I'm sick as a dawg right now.
Grrr1337
« Reply #35 on: December 05, 2016, 06:34:12 PM »
Thanks for comfirming, I feel relatively new for theswamp so I have no idea whats below the surface, expect big fishes.
vevo.bg
« Reply #36 on: December 05, 2016, 06:51:18 PM »
Given a couple quick and dirty functions (not hardly optimized) ...
(defun _Positions ( x lst / p )
    ;;  find all the positions of x in lst
    ;;  (_Positions 1 '(0 0 1 0 0 1)) >> (2 5)
    (if (setq p (vl-position x lst))
        (   (lambda ( lst result )
                (while (setq p (vl-position x lst))
                    (setq
                        result (cons (+ 1 p (car result)) result)
                        lst    (cdr (member x lst))
                (reverse result)
            (list p)
(defun _Tally ( x lst )
    ;;  count all the occurances of x in lst
    ;;  (_Tally 1 '(0 0 1 0 0 1)) >> 2
    (length (_Positions x lst))
(defun _Distil ( lst / result )
    (while lst
        (setq
            result (cons (car lst) result)
            lst    (vl-remove (car result) (cdr lst))
    (reverse result)
(defun _TallyHo ( lst )
    (mapcar
        (function (lambda (x) (cons x (_Tally x lst))))
        (_Distil lst)
Then ...
(_TallyHo
       ("A" "B" 10)
       ("A" "C" 20)
       ("B" "C" 10)
       ("A" "B" 10)
       ("A" "C" 20)
       ("A" "B" 10)
   (("A" "B" 10) . 3)
   (("A" "C" 20) . 2)
   (("B" "C" 10) . 1)
Cheers (now where'd I'd leave that big bowl ...).
Marc'Antonio Alessi
  • Marco
« Reply #37 on: December 06, 2016, 03:06:05 AM »
If we can go on demential:
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Length   : 160000    Positions: 16
Elapsed milliseconds / relative speed for 512 iteration(s):
    (ALE_POSITIONSD 1 ALIST).....1828 / 2.56 <fastest>
    (ALE_POSITIONSD 1 ALIST).....1844 / 2.53
    (MP_POSITIONS 1 ALIST).......4625 / 1.01
    (MP_POSITIONS 1 ALIST).......4672 / 1 <slowest>
; 20161206
(defun ALE_PositionSd (i l / n r c) ; ALE_PositionS(demential)
  (setq n -1)
  (while (setq c (vl-position i l))
    (setq l (cdr (ALE_List_NthCdr c l))  r (cons (setq n (+ 1 c n)) r))
  (reverse r)
ALE_List_NthCdr  see: https://www.theswamp.org/index.php?topic=46419.msg514475#msg514475
Grrr1337
« Reply #38 on: December 06, 2016, 04:15:52 AM »
This is a good start, thanks alot MP!  :yay!:
vevo.bg
« Reply #39 on: December 06, 2016, 10:55:24 PM »
You're very welcome, thanks for the thanks, cheers.
