Author Topic: A variable both as Local And Global  (Read 1378 times)
NirantarVidyarthee
« on: January 20, 2013, 01:25:25 PM »
I am seeing an program that has the same variable used both global as well as local. Its working. So I am confused.
Example: (defun x / x)
What is the purpose of this? Why not use two different variable? Also won't they clash?
Re: A variable both as Local And Global
« Reply #1 on: January 20, 2013, 01:59:49 PM »
My guess is a typo when declaring local variables.
There is no clash as the argument symbol will hold the value passed when the function is called, e.g.:
_$ (defun f ( a / a ) (print a) (princ))
F
_$ (f 10)
10
However, you will receive a warning when checking the code using the VLIDE Check Utility (as described here).
NirantarVidyarthee
« Reply #2 on: January 20, 2013, 02:34:06 PM »
Thanks Lee,
It indeed gives an error in stats.
But since this is from code supplied by AutoDESK, I was just wondering if it was by design for a specific purpose.
irneb
« Reply #3 on: January 21, 2013, 01:58:08 AM »
No it's probably a typo from whoever wrote that lisp. It's definitely not helpful to have a local var clash with a parameter name. AutoLisp ignores the local var (as Lee's shown) - fortunately - if it was the other way round it would have been disastrous, at present it's only dangerous  :ugly: .
BTW, what you're referring to is not actually a "Global" variable. It's a parameter passed into a function. E.g.
(setq A 1)
(defun test (B / C)
  (setq C (+ B A)))
Note here A is a global, B is a parameter and C is a local.
