Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Right angle dimension display!!
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Right angle dimension display!! (Read 4299 times)
theluck19
Newt
ABC (ADDICTED to BOOZE & CAD.)
on:
January 19, 2013, 05:15:15 AM »
Can AutoCAD (2013) display right angle dimensions alone in the traditional way? Any way to customize the DIMSTYLE ??
Logged
Win 10 Pro 64+AutoCAD 2019
bgingerich
Guest
Re: Right angle dimension display!!
Reply #1 on:
January 23, 2013, 01:05:12 PM »
Not that I'm aware of...
Any particular reason you need this?
Logged
BlueMoon
Guest
Reply #2 on:
January 23, 2013, 03:31:48 PM »
I'm not aware of a dedicated dimension like this but I like to keep things I use off to the side of drawings that I use often. I simply put these in to whatever drawing I'm working on and drag them over when I need them. They are already on the correct layer so it saves quite a bit of time.
BM
Logged
JNieman
Water Moccasin
Reply #3 on:
January 23, 2013, 03:36:37 PM »
I'd be interested. I've fallen away from using that efficient, standardized, and widely understood symbol in favor of the larger, bulkier dimension. I'd mostly forgot about it because Autocad had changed my drafting habits, tbh.
Logged
theluck19
Newt
Reply #4 on:
January 23, 2013, 11:22:21 PM »
This particular client wants to show that the brace is running at 45 Degrees by using this display method. I used AutoCAD's normal angular dimension, just to be told that it is improper to show a right angle this way!! Any Ideas??
Logged
bchapman
Guest
Reply #5 on:
February 01, 2013, 10:14:32 PM »
Couldn't you modify the dim style to exclude the extension lines / arrow, and keep text oriented 0? Just a thought.... haven't tried it.... not sure how to solve the right-angle symbol thingy though
Logged
Bob
Guest
Reply #6 on:
February 14, 2013, 04:06:38 PM »
Isn't it just a symbol?
Can you create a block and insert it on the vertex/
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
