Author Topic: Multileader Z Value  (Read 6735 times)
Dave M
Multileader Z Value
« on: January 17, 2013, 11:45:35 AM »
Does anyone have a quick way to set/change the elevations of multileaders?
Cheers
Civil 3D 2018 - Microstation SS4 - Windows 10 - Dropbox
Re: Multileader Z Value
« Reply #1 on: January 17, 2013, 12:03:28 PM »
Try something like this:
(defun c:foo (/ e elev ss)
    (and (setq elev (getdist "\nEnter elevation: ")) (setq ss (ssget ":L" '((0 . "MULTILEADER")))))
     (while (setq e (ssname ss 0))
       (entmod (mapcar '(lambda (x)
  (if (member (car x) '(10 12 110))
    (list (car x) (cadr x) (caddr x) elev)
    x
       (entget e '("*"))
       (ssdel e ss)
Dave M
« Reply #2 on: January 17, 2013, 12:43:57 PM »
That worked perfectly, thanks!  BTW why is the function named foo?
Cheers
Dave
« Reply #3 on: January 17, 2013, 12:54:36 PM »
Dave M
« Reply #4 on: January 17, 2013, 01:06:13 PM »
Got it, thanks!
lamarn
« Reply #5 on: January 23, 2013, 05:04:15 AM »
How does this work? I do see that elevation is not a property listed.. (?)
« Reply #6 on: January 23, 2013, 11:06:01 AM »
All I did was dump the entity data then looked for point lists within and modified them with ENTMOD  8-)
